D16Z6 questions?
Old Nov 23, 2004 | 01:29 PM
Mach69's Avatar
Default D16Z6 questions?
No, this isn't one of those, omg how do I put a Z6 into my car? More like...
Im buying a D16Z6 tomorrow! And a 4th gen si tranny! It has no accessories on it (the Z6) besides exhaust manifold. So I'm wondering if the starter, alternator, and a/c compressor are the same for my D15B1 in my STD. Also, when he pulls out the engine, how can I tell it is a Z6. I know there is a stamp somewhere on the engine block, but if you could decsribe to me where it is or post a pic of where it is. That would be perfect. If I buy a hondata s200, can I engage vtec (NOT VTECH!) myself? I'll post pics if I buy it tomorrow.
Old Nov 23, 2004 | 01:31 PM
iphatcrxi's Avatar
Default Re: D16Z6 questions? (Mach69)
Does the wiring harness from an OBD-0 PM6 ECU plug into an OBD-1 P28 ECU?
iphatcrxi's Avatar
Default Re: D16Z6 questions? (iphatcrxi)
I have a 91 CRX Si and im doing the mini-me swap, i everyone says i need a P28 ECU, but don't i need a different wiring harness then?
Old Nov 23, 2004 | 01:34 PM
EJ2-Fluffy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 &raquo;</TD></TR><TR><TD CLASS="quote">No, this isn't one of those, omg how do I put a Z6 into my car? More like...
Im buying a D16Z6 tomorrow! And a 4th gen si tranny! It has no accessories on it (the Z6) besides exhaust manifold. So I'm wondering if the starter, alternator, and a/c compressor are the same for my D15B1 in my STD. Also, when he pulls out the engine, how can I tell it is a Z6. I know there is a stamp somewhere on the engine block, but if you could decsribe to me where it is or post a pic of where it is. That would be perfect. If I buy a hondata s200, can I engage vtec (NOT VTECH!) myself? I'll post pics if I buy it tomorrow. </TD></TR></TABLE>
As far as I'm concerned, all the D series alternators, starters, A/C compressors will fit on the engine. You can tell it is a D16z6 by looking at the code stamped on the block on the left side of the exhaust manifold. You'll see a flat area usually it has oil stains over it. Just get a rag and wipe it off and you can tell. If you get a hondata chip, yes you can engage Vtec at any setting it has been programmed to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iphatcrxi &raquo;</TD></TR><TR><TD CLASS="quote">Does the wiring harness from an OBD-0 PM6 ECU plug into an OBD-1 P28 ECU?</TD></TR></TABLE>
The wire harness from an OBD-0 Will not plug into an OBD-1 p28 ECU. You will need a OBD-0 to OBD-1 conversion harness. There are a few reputable makers on the boards that can help ya. Blown90hatch being one of them.
-Jon
Old Nov 23, 2004 | 01:40 PM
iphatcrxi's Avatar
Default Re: D16Z6 questions? (CRX-Fluffy)
Is there an ECU with vtec that is OBD-0?
Old Nov 23, 2004 | 03:56 PM
longislandek123's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iphatcrxi &raquo;</TD></TR><TR><TD CLASS="quote">Is there an ECU with vtec that is OBD-0?</TD></TR></TABLE> I am pretty sure the only 0bd0 ecu with vtec is for a b16. But I am also pretty sure you can get a vafc to activate Vtec on a pre obd car.
Old Nov 23, 2004 | 04:05 PM
iphatcrxi's Avatar
Default Re: D16Z6 questions? (GoFastMotorSports)
i was told you can use the pg7 ecu from an integra, its obd0 and has vtec, but do i need a ZC dizzy or can i use my A6 dizzy?
Old Nov 23, 2004 | 06:12 PM
mr. carpenter's Avatar
you'll need the dist. that matches your ecu. i got a zdyne one wire and stayed obd0.
Old Nov 23, 2004 | 06:21 PM
metric's Avatar
Default Re: D16Z6 questions? (mr. carpenter)
pr3 or pw0 are both obd0 (jdm) and for b16's but they will run a sohc vtec, you'll just need to run a few wires.
Adam Smith
Oct 21, 2022 07:16 PM
biff206
42
Nov 5, 2013 02:54 AM
alexzhere
Jun 4, 2013 01:35 PM
batman21
Feb 20, 2005 12:55 PM
r30slick
Mar 14, 2002 10:59 AM
