Prothane rear trailing arm bushing: legal STS
Old Nov 23, 2004 | 08:49 AM
RAB's Avatar
RAB
Default Prothane rear trailing arm bushing: legal STS
Simple question are the Prothane rear trailing arm bushings legal in STS I would think they are. Car being 89-91 Civic Si.
Old Nov 23, 2004 | 09:35 AM
Targa250R's Avatar
be professional
Default Re: Prothane rear trailing arm bushing: legal STS (RAB)
Many of the (2004 season) ST rules and guidelines can be found here: http://www.moutons.org/sccasol...NSION
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">14.8.B Suspension bushings may be replaced with bushings of any materials (except metal) as long as they fit in the original location. Offset bushings may be used. In a replacement bushing the amount of metal relative to the amount of non-metallic material may not be increased. This does not authorize a change in type of bushing (for example ball and socket replacing a cylindrical bushing), or use of a bushing with an angled hole whose direction differs from that of the original bushing. If the Stock bushing accommodated multi-axis motion via compliance of the component material(s), the replacement bushing may not be changed to accomodate such motion via a change in bushing type, for example to a spherical bearing or similar component involving internal moving parts. Pins or keys may be used to prevent the rotation of alternate bushings, but may serve no other purpose than that of retaining the bushing in the desired position.</TD></TR></TABLE>
So yes, you can use poly bushings in STS.
I would actually recommend going with OEM Honda or Mugen rubber bushings for the rear trailing arm, though. The big solid polyurethane bushings apparently don't allow enough of the multi-axis movement required of that particular bushing, which in turn can cause the suspension to bind. You can find more information on that issue in the RR/AX forum.
Jon Petersen
Dec 19, 2018 06:12 AM
OMG WTF
Suspension & Brakes
Jul 20, 2006 07:49 PM
viper1984
21
Feb 28, 2006 06:21 AM
Jays91DXhatch
Apr 27, 2005 08:19 PM
RAB
32
Dec 20, 2004 03:16 PM
