Megan rear Lower Control Arms
Old Nov 23, 2004 | 03:37 AM
ironlung78's Avatar
Default Megan rear Lower Control Arms
my rear lower control arm bushings are just about done...(clankety clank!).
After looking around I ended up just buying the Megan Racing Aluminum arms with bushings. Probably going to install them on Turkey Day..
I would of bought SPC or SRR but they didn't look any different for over $100 more. Can't find anything on them so lets here what you guys have to say..
I'll repost after they are installed
Old Nov 23, 2004 | 03:59 AM
6SPD_EK's Avatar
Default Re: Megan rear Lower Control Arms (sidesi)
do a search...click archive topics - limit search to "eg + /del sol forum" & search for "megan"
been covered before - the busings that come with those are ****
edit see here
https://honda-tech.com/zerothread?id=984808
Old Nov 23, 2004 | 04:17 AM
chris_c's Avatar
Default Re: Megan rear Lower Control Arms (adirondackR)
unless your car is a 96+ you are going to need to use 4 washers [two on each side] of the LCA to take up the space between the strut and bushing on the LCA.
i know people that HATE the megan LCA's and others that are actually quite happy with them. i see it this way, you already have them so bolt them up. if you end up not liking them swap them back out. they are $80 bucks. prolly spend more money out at the bar over the weekend...
Old Nov 23, 2004 | 07:39 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Megan rear Lower Control Arms (chris c)
Over time, those washer will compress causing your lower shock mounting bolt to be sheared off.
SPOOLINmatt
Suspension & Brakes
21
Dec 22, 2010 03:40 PM
D15B Civic
Suspension & Brakes
11
Apr 30, 2010 10:47 AM
xxx99ludexxx
Jan 24, 2009 01:29 PM
racer_X_123
Suspension & Brakes
Feb 10, 2005 09:13 PM
