93 Hatch Leaking Water Into Driver's Side Carpet / Foot Area HELP!!!!
Old Nov 22, 2004 | 06:27 PM
93CharcoalHatch's Avatar
Default 93 Hatch Leaking Water Into Driver's Side Carpet / Foot Area HELP!!!!
heyyy, anyone who has had a similar problem or knows what this can be PLEASE let me know because im getting sick of drying my carpets lol.
Ok i have a 1993 hatchback DX and i noticed water on the carpets by the foot area on the drivers side. i dryed but the next rain it came back.
I DID NOT DRIVE THE CAR SINCE DRYING and the water came back so that crossed out the idea of water spray off the tires.
i then went down in my car and had a friend pour pots of water on the right side of my windshield area and didnt see anything coming in.
ANYONE that has ANY ideas please let me know im clueless
THANKS!!!
Old Nov 22, 2004 | 06:36 PM
JDM-EJ1's Avatar
Default Re: 93 Hatch Leaking Water Into Driver's Side Carpet / Foot Area HELP!!!! (93CharcoalHatch)
Same thing happens on my bros DA9. 'cept it's his passenger side. Bump for wanting to know to.
Old Nov 22, 2004 | 06:41 PM
Default Re: 93 Hatch Leaking Water Into Driver's Side Carpet / Foot Area HELP!!!! (JDM-EJ1)
Bump im puzzled
Old Nov 22, 2004 | 06:46 PM
JV's Avatar
JV
Who?
This is all i could find on the subject...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">24. 92-050 FEB 97 Body - Water Leak From Seam Under Corner of the Dash </TD></TR></TABLE>
http://www.alldata.com/TSB/24/92240273.html
Old Nov 22, 2004 | 07:00 PM
Default Re: 93 Hatch Leaking Water Into Driver's Side Carpet / Foot Area HELP!!!! (JV)
will definitley look into that THANKS!!! Bump for any more ideas
Old Nov 22, 2004 | 07:09 PM
Ricey McRicerton's Avatar
In my EK, the hose that went from the A/C evaporator (under the passenger side kick panel) to the engine bay used to leak like crazy. I just ran a bead of silicone around the edge of it and it stopped.
Revtek 2's Avatar
For JDM-EJ1: the leak on the DA9 is probably a cowl leak...it happened to my old DA as well and you can fix it buy replacing the rubber gromets (spelling) underneath the cowl, but for better instructions you can go to http://www.g2ic.com/tegtips/interior/15.html AND to 93CharcoalHatch: my 95 Coupe did the same thing but when I changed my windshield moldings it stopped leaking, not sure if it would do the same in your case though.... Good Luck
Modified by Revtek 2 at 8:28 PM 11/22/2004
Old Nov 22, 2004 | 07:17 PM
Default Re: (Revtek 2)
Thanks for the help bump
Old Nov 22, 2004 | 07:29 PM
07's Avatar
07
Default Re: (93CharcoalHatch)
Passenger side is USUALLY just a plugged up evaporator drain hose. If you have A/C
Old Nov 22, 2004 | 08:05 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (Calculator)
I sent you a PDF file copy of the Honda Service Bulletin. There has been problems with the seam sealer around the hood hinge and other panels that cause leaks into the driver side corner, under the dash- that are really hard to find.
Old Nov 23, 2004 | 03:16 AM
Default Re: (Emerika)
Thank you so much! I will be taking fender off this weekend and testing that PDF I Hope its as simple as a seal.
Old Nov 23, 2004 | 06:16 PM
Evs-One's Avatar
Solbros Owns Me
no, PDF is the type of file- you need the Adobe Reader software to see it.
Old Nov 24, 2004 | 12:05 PM
i know lol thats what i meant by i was going to test it. I will be inspecting my car using the information in that PDF. Thanks again!!! and BUMP for more info Please
Old Nov 24, 2004 | 08:44 PM
bump for more info please let me know anything you know or if you have had similar problems and how you fixed them lol
Old Nov 27, 2004 | 04:53 AM
hey everyone i ended up bringin my car to a body shop and they found a leak in the top of the drivers side of the windshield. I brought my car to an auto glass shop and they said the water could have been collecting in my head liner and either running down the windshield or down the a-pillar. So i have an appointment Monday morning at 9AM to get a new windshield put in the right way, and im hopping this stops my leak to the carpets lol thanks for your help everyone !!!
NOFX
Jul 17, 2009 10:04 PM
carlooooo
Feb 13, 2007 12:35 PM
biscuit01ex
Honda Civic (2001 - 2005)
Apr 30, 2006 11:20 PM
Truecure
Nov 3, 2004 12:33 PM
crxaddikt
Oct 28, 2002 02:35 PM
