DOES a del sol S model have a front sway bar?
Old Nov 22, 2004 | 05:39 PM
MiX's Avatar
MiX
Default DOES a del sol S model have a front sway bar?
DOES a 1994 del sol S model have a front sway bar?
Old Nov 22, 2004 | 05:44 PM
B16Drag's Avatar
Default Re: DOES a del sol S model have a front sway bar? (MiX)
no
Old Nov 22, 2004 | 06:34 PM
DelsoldS's Avatar
Default Re: DOES a del sol S model have a front sway bar? (B16Drag)
what would need to be done to install a stock sway bar off a si?
Old Nov 27, 2004 | 01:11 PM
dwnthehatch's Avatar
Default Re: DOES a del sol S model have a front sway bar? (DelsoldS)
You need the front lca's, end links, sway bar. See my sig. I have all of the parts you need.
Old Nov 27, 2004 | 02:07 PM
Jayboy's Avatar
uhhhh yeah they do. I have a S model and it DOES have a front sway. Just go look, you should be able to see it if you turn the wheel all the way.
Old Dec 3, 2004 | 06:25 PM
B16Drag's Avatar
wtf?
724chris
Mar 20, 2011 06:21 PM
nomoshing
Suspension & Brakes
Feb 11, 2010 01:47 PM
del spool
Dec 18, 2009 07:15 PM
Black_Sol
Oct 7, 2005 10:57 AM
