BLOX sway bar
BLOX sway bar
I recently purchased a BLOX sway bar for my '96 del Sol. When I went to put it on I soon found out that the end links are to wide to properly fit the sway bar. Does anyone know if the end links from, say an Integra, are narrower then the stock ones on my del Sol? My end links have a 1 inch gap where the sway bar mounts, I need ones with like a 1/4 inch gap, or bushings of some sort. Also, I was told I should invest in subframe reinforcement, like an A-Spec model. Is this true?
MiX
12-03-2004 06:25 PM
