Did a search and nothing is helping....Header gasket
Old Nov 22, 2004 | 12:13 PM
EliteCivicX's Avatar
Default Did a search and nothing is helping....Header gasket
so i have an aftermarket 4-2-1 header. the gasket between the top piece of the header and the bottom piece is basically shot......(NOT THE ONE between the header and cat) i have looked every.....summitracing, manufacture, everything and cant find ****.
its a 2 big hole 3 bolt gasket...................any sites or ne ideas how to replace? its causing a major exhaust leak.
Old Nov 22, 2004 | 12:28 PM
hatchi's Avatar
Default Re: Did a search and nothing is helping....Header gasket (EliteCivicX)
how bout muffler shops?? your old stock one?
Old Nov 22, 2004 | 01:19 PM
DelSolDon's Avatar
try a high-temp gasket maker from permatex, or if you're not going to be seperating the header again, try some "muffler weld" or bandage, you may want to (if the mating surfaces are warped) just sand or plane them down first before trying anything else
Old Nov 22, 2004 | 02:01 PM
EK k kay's Avatar
Any muffler shop should be able to make you or find one for a few bucks.
Old Nov 23, 2004 | 11:37 AM
Default Re: Did a search and nothing is helping....Header gasket (chowmien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chowmien &raquo;</TD></TR><TR><TD CLASS="quote">Any muffler shop should be able to make you or find one for a few bucks.</TD></TR></TABLE>
thanks ill check that out tonite.
ne more opinions?
Old Nov 23, 2004 | 11:45 AM
Ghetto Civic HX's Avatar
I love to drive
Bump because I'm in the same boat. BTW, want brand of header do you have?
Old Nov 23, 2004 | 11:58 AM
IVI's Avatar
IVI
Default Re: Did a search and nothing is helping....Header gasket (Ghetto Civic HX)
i would probably goto a muffler shop for that.
however i have heard of people making their own.
Old Nov 23, 2004 | 12:15 PM
JDMlyfestyle's Avatar
my buddy had the same problem with his VW corrado. our local advanced auto had some "make ur own gasket kit. it kinda looked like dynamat but it worked and it was only $6 for a 24"x24" piece
Old Nov 23, 2004 | 02:27 PM
CLMTAutoXR888's Avatar
Default Re: Did a search and nothing is helping....Header gasket (IVI)
Yeah u can make a gasket, go to your local autoparts store (like NAPA, not Pepboys) and ask 4 "HI-TEMP Gasket Maker"... actually I don't kno what they call it but it comes in sheets.
You line it up to the part and using a small hammer u tap the gasket sheet onto the flange of the header. By denting the shape of the desired form of gaket onto the sheet u can then rip the perfect sized gaket off and still have material for future gaskets.
Don't know if that makes any sense to u but I thought I'd try and explain. Wish I could show u a picture but I did it at a friend's garage way out in the booney's (redneck El Cajon, CA).
Old Nov 23, 2004 | 03:12 PM
lohatch's Avatar
Default Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">my buddy had the same problem with his VW corrado. our local advanced auto had some "make ur own gasket kit. it kinda looked like dynamat but it worked and it was only $6 for a 24"x24" piece</TD></TR></TABLE>
/\/\ do that
ooosorio
Honda Civic (2001 - 2005)
Jul 12, 2016 04:20 PM
Racermech
Sep 23, 2006 06:55 PM
brockscivic
10
Feb 23, 2005 04:20 PM
BLK98EX
Sep 25, 2004 10:21 PM
ActiveAero
Jun 20, 2003 01:47 PM
