Will HX WHEELS clear 92-95 SI Brakes?
Old Nov 22, 2004 | 12:12 PM
Vincent.'s Avatar
Default Will HX WHEELS clear 92-95 SI Brakes?
let me know please...thanks!
Old Nov 22, 2004 | 12:18 PM
Eskay@JDMCircle.com's Avatar
It did on mine, not sure about ABS versions tho?
Old Nov 22, 2004 | 12:22 PM
sohcvtec1995's Avatar
Default Re: (skt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skt &raquo;</TD></TR><TR><TD CLASS="quote">It did on mine, not sure about ABS versions tho?</TD></TR></TABLE>
i dnt know how you managed that. With out modifying the caliper.
Old Nov 22, 2004 | 12:27 PM
agent marlon's Avatar
Default Re: (sohcvtec1995)
use really thin wheel spacers or just shave off a little bit of the caliper using a dremel.
Old Nov 22, 2004 | 12:31 PM
dumbchild's Avatar
Default Re: Will HX WHEELS clear 92-95 SI Brakes? (SuperVince)
Mine fit with no modification.
(HX on 93si)
Old Nov 22, 2004 | 12:35 PM
Mike_C's Avatar
definitely should.
Old Nov 22, 2004 | 01:02 PM
Targa250R's Avatar
be professional
As long as your EH3 Si doesn't have ABS, HX wheels will fit on it with no modifications.
If you have a '94 Si with ABS, then you will need to either grind down the caliper bracket or use a spacer.
Old Nov 22, 2004 | 01:07 PM
beerbongskickass's Avatar
Default Re: Will HX WHEELS clear 92-95 SI Brakes? (Targa250R)
I have a 95 civic coupe EX, so if the 92-95 SI brakes are the same, they will not fit without spacers. I am guessing the brakes are different though since a few people posted they fit HX wheels on there SI without spacers. I am using H&R 5mm spacers and I don't have ABS.
Old Nov 22, 2004 | 01:46 PM
Targa250R's Avatar
be professional
Default Re: Will HX WHEELS clear 92-95 SI Brakes? (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">I have a 95 civic coupe EX, so if the 92-95 SI brakes are the same, they will not fit without spacers. I am guessing the brakes are different though since a few people posted they fit HX wheels on there SI without spacers. I am using H&R 5mm spacers and I don't have ABS.</TD></TR></TABLE>
AFAIK, all EXes had 10.3" front brakes, so you will probably need to shave down the caliper.
Old Nov 22, 2004 | 01:50 PM
pwrofdrm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
AFAIK, all EXes had 10.3" front brakes, so you will probably need to shave down the caliper.</TD></TR></TABLE>
nope...just the caliper
Old Nov 22, 2004 | 01:54 PM
DJ_SaNdOz's Avatar
Default Re: Will HX WHEELS clear 92-95 SI Brakes? (lax1185)
And IIRC only the 94 Si's had ABS, so they should be fine on the non ABS versions.....
1kleenef
Feb 12, 2009 06:22 PM
alexb18c1
Jul 10, 2008 04:04 AM
ocular
Sep 26, 2007 09:24 AM
Dangydang
20
Apr 22, 2003 02:10 PM
Slow Egg
Sep 6, 2002 01:10 PM
