HELP!! Temp. is sitting too hot!!!
Old Nov 22, 2004 | 04:50 AM
H22EKHATCH's Avatar
Default HELP!! Temp. is sitting too hot!!!
OK guys i'm not sure what the hell is going on w/ my car?
for two years the temp. guage sat at a little higher than
1/3 up. Now for the last three weeks it holds at a little over
1/2 way up...
side note I have a stock JDM h22a motor,
I have a del sol radiator with an fal fan to help cool
HELP any suggestions
Old Nov 22, 2004 | 08:52 AM
tblazak's Avatar
Default Re: HELP!! Temp. is sitting too hot!!! (H22EKHATCH)
Could be that your block is needs to be flushed. After time the calcium ions in water react and precipitate out of the water in the form of calcium carbonate and others. Go to you favorite autoparts store and pick up some penzoil super flush. It will disolve all of the crap that is growing inside. make sure that when you do it you do not run the heater right away, or else all of the floating junk might get stuck in your heater core.
Good luck!
Old Nov 22, 2004 | 11:37 AM
H22EKHATCH's Avatar
Default Re: HELP!! Temp. is sitting too hot!!! (tblazak)
huh, worth a try, I'll let you know if it worked, thanks
Old Dec 1, 2004 | 04:50 AM
H22EKHATCH's Avatar
Well thanks i tried flushing system--helped none---
but thanks for the reply, anyone else...
Old Dec 1, 2004 | 05:59 AM
joshuavillasenor's Avatar
Check the one wire sensor under the dizzy. Alot of times oil leaks will cause a poor connection. If that good measure the actual resistance of the sensor and compare to spec.
***NEVER INSTALL A ONE WIRE SENSOR WITH RTV***
Old Dec 1, 2004 | 09:06 AM
Crazydave's Avatar
Default Re: HELP!! Temp. is sitting too hot!!! (joshuavillasenor)
Could be several things
Check the level of coolant
Check the cap
radiator could be getting plugged up (or is just old) and not working efficiently
thermostat could not be opening all the way
could have a leak
could be a bad temp sending unit
Old Dec 1, 2004 | 09:59 AM
H22EKHATCH's Avatar
Default Re: HELP!! Temp. is sitting too hot!!! (Crazydave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazydave &raquo;</TD></TR><TR><TD CLASS="quote">Could be several things
Check the cap
could have a leak
I obviously checked level of coolant
replaced the cap,
changed the thermo.
got new radiator
checked for leaks
come on guy I wouldn't waste peoples time like that,
thanks though will check the temp sending unit
Old Dec 1, 2004 | 10:00 AM
H22EKHATCH's Avatar
Sorry didn't mean to sound like a D!ck Im just frustrated,
thanks EVERYONE for the help....
Old Dec 3, 2004 | 02:28 AM
sinister6's Avatar
how did you flush it?
proper way to flush the entire route, is to disconnect the upper hose and keep water pour into the radiator for 15 mins. you should see loads of build-up flushed out from the upper host after, i got a full coke can of build up last time .
Old Dec 3, 2004 | 07:35 AM
Dan GSR's Avatar
Default Re: (sinister6)
how would that work though?
as soon as the cold water hits the thermostat, it would start closing
Old Dec 5, 2004 | 05:35 PM
sinister6's Avatar
wasnt the thermostat sitting at the exit of the water route? keep your engine running and they will be circulate out after some higher temp
at least this is what my mechanic tells me to do..
Old Dec 5, 2004 | 07:02 PM
Dan GSR's Avatar
water flows from the bottom of radiator to the thermostat, thru the engine, back into the top of the radiator
Old Dec 5, 2004 | 07:06 PM
sinister6's Avatar
bleh.. LOL
its either big hose, now im sure about the procedure. just the different hose i think
thx for correction
B18C-REXXX
Jul 26, 2007 10:02 AM
RedHB..D15B
Apr 19, 2004 12:06 PM
spart
Feb 27, 2002 04:07 PM
