EG/EK Shock switch
Old Nov 21, 2004 | 09:22 PM
H22A_HB
Guest
Posts: n/a
Default EG/EK Shock switch
well i just traded my EK-HB for a EG-HB the person that owned the EG wants his Tiens shocks to put them on the EK i was wondering if the EK shocks will fit my EG (They are Tokico) the ones that our on the EK will be going to the EG
Old Nov 21, 2004 | 09:54 PM
b18bcivic's Avatar
Default Re: EG/EK Shock switch (H22A_HB)
i think they'll fit but u'll need ek rear lca's
Modified by b18bcivic at 7:27 AM 11/22/2004
Old Nov 21, 2004 | 10:14 PM
A_RU_BA's Avatar
Default Re: EG/EK Shock switch (b18bcivic)
fronts will fit but not the rear
yjacketr's Avatar
Well i did the opposite i fitted eg shocks to a ek and they bolted right up.
Old Nov 21, 2004 | 10:32 PM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bcivic &raquo;</TD></TR><TR><TD CLASS="quote">i think they'll fit but u'll need ek rear lca's
Modified by b18bcivic at 7:27 AM 11/22/2004</TD></TR></TABLE>
EK lca's will mess up your your rear suspension geometry. EK rear shocks will fit on EG lca's if you machine off about 1/8" off each side of the lower shock bushing/mount. i know this b/c i have EK shock on my EG
:edit:
some tockico shocks are the same for EG's and EK's, and they include washers to fill in the extra space between the fork and the mount on ek's.
Old Nov 21, 2004 | 10:55 PM
Calvinator's Avatar
Default Re: EG/EK Shock switch (yjacketr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yjacketr &raquo;</TD></TR><TR><TD CLASS="quote">Well i did the opposite i fitted eg shocks to a ek and they bolted right up. </TD></TR></TABLE>
YOu didn't have any problems bolting up the rear eg shocks on the ek? Isn't the lower fork on the rear shocks too short (legs are too short) for how tall the ek lca is?
Old Nov 21, 2004 | 11:14 PM
=GAME='s Avatar
Default Re: EG/EK Shock switch (xtremeazian)
eg shocks to ek, youll need to add washers.
ek to eg, like someone mentioned, you need to shave off a bit by the bushing.
BlitzSix
Mar 18, 2009 12:01 PM
vizsual00
24
May 26, 2004 10:09 PM
vizsual00
May 14, 2004 06:50 AM
chad
Dec 15, 2003 01:21 PM
