b16a with ctr piston and ctr cams, what ecu or chip
Old Nov 21, 2004 | 09:10 PM
asocallocal's Avatar
Default b16a with ctr piston and ctr cams, what ecu or chip
im am getting my project together and the set is b16a with ctr piston and ctr cams. my question is what would be better or best for this set up.
as of now, stock p30 will power it.
will a fpr be good enough to power it with the p30? or would a chiping be the best. if chipping is the best way to go, what chip shuold i use or what should be the vtec crossover be so i can get a custom one.
i know u all motor guys should know this. and i know some1 has this set so please help asap. project almost done.
Old Nov 21, 2004 | 10:40 PM
onepoint6i's Avatar
Default Re: b16a with ctr piston and ctr cams, what ecu or chip (asocallocal)
You can run any chip you please, We ran a Jun and mugen copy chips in my homies EF with P28...it ran hard..i would run FPR @ 50-60psi(with no vaccume signal attached) then mess with your VAFC..But i recomend getting it dynoed
BTW this setup loves to rev but i would rec keeping your fuel cut off at no more than 9,500rpm..you would shift at around 9000rpm though...I say this cause theres going to be those mishifts (trust me) and you dont want to crush a bearing..
Old Nov 23, 2004 | 06:54 PM
bump!
alittle more info on this.
p30 with fpr OR chipped ecu?
which will be better, mugen or skunk2 program?
WHAT IS THE BEST VTEC CROSSOVER FOR CTR CAMS?
Old Nov 23, 2004 | 07:09 PM
THEUSED's Avatar
Is this a drag motor, cause your comp is going to be high
Old Nov 23, 2004 | 07:18 PM
mmuller's Avatar
Mad Scientist
Default Re: (THEUSED)
you need a custom program to support that compression. All those knock off chips are crap.
get a program made for your needs
Old Nov 23, 2004 | 08:03 PM
f@sth@tch89's Avatar
try ericksracing.............
http://ericksracing.com/ecus.htm
im running a reprogrammed pr3 on my b16 w/ ctr internals.
Old Nov 24, 2004 | 08:38 PM
Default Re: b16a with ctr piston and ctr cams, what ecu or chip (fasthatch89)
what is ur vtec cross over FASTHATCH89?
mmuller, what kink of program will i need? my compression should be at 11.5 or so. let me know what up. i need to know more info so i can just order one or get one custom made. thanks
Old Nov 26, 2004 | 02:11 AM
Mike@K-Tuned's Avatar
I would recomend using your P30 with an FPR and a VAFC if your budget is tight. Otherwise I would go with a chipped P28ecu (Erick's racing is good) and hondata, but the problem here is that you'll have to spend some time and money on the dyno to get it running at full potential safely. I'm pretty sure you'll want your VTEC cross over in between 5200-5600rpm. The dyno graph will tell you the best rpm though. Good luck
Old Nov 26, 2004 | 11:06 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asocallocal &raquo;</TD></TR><TR><TD CLASS="quote">what is ur vtec cross over FASTHATCH89?
5500 rpm.....im using an ERE reprogrammed PR3
moddedmuskegon
May 2, 2008 09:41 AM
russian_racer
43
Mar 9, 2005 09:18 AM
JoeSiR
Jun 27, 2002 07:44 PM
Cory man
May 9, 2002 07:13 PM
SilentFury
Feb 9, 2002 06:30 PM
