should i get my new block's deck resurfaced?
Old Nov 21, 2004 | 07:40 PM
SOHC_MShue's Avatar
Default should i get my new block's deck resurfaced?
hey guys as you have seen i've been having some major headgasket issues and this time around I am replacing my entire motor because i am sick of the old one which has blown 3 in under 7 months even with arp headstuds and a resurfaced head. Well i got a new head and a block that is in very good shape. It has about 85k on it and has never been beaten on(swapped for a B). Would I be ok just resurfacing the head and not worrying about the block since it has never been through any real abuse? I also have a brand new set of arp headstuds for this motor.
Modified by SOHC_MShue at 2:16 AM 12/1/2004
Modified by SOHC_MShue at 2:17 AM 12/1/2004
Old Nov 21, 2004 | 07:50 PM
Bailhatch's Avatar
Default Re: should i get my new block's deck resurfaced? (SOHC_MShue)
do the block. Since you're sick of HG problems, I'm surprised that you even thought of skimping on a $75 job.
Old Nov 21, 2004 | 08:13 PM
SOHC_MShue's Avatar
Default Re: should i get my new block's deck resurfaced? (Bailhatch)
ehh...its not the money..i have just never pulled apart my bottom end before and i'm gonna have to do that in order to get the block resurfaced.
I really just don't have much time to deal with it right now.
Old Nov 21, 2004 | 08:22 PM
incredteg3's Avatar
my opinion is do it right the first time (get it decked) if you don't know what you are doing witht the block don't do it, have the machine shop assemble it. "its not the money" or have them help you do it. if your shop is cool you can say i would like to learn more and they will say ok come in and we will put it together with you. that way next time you will be confident to do it yourself. good luck
Old Nov 21, 2004 | 09:45 PM
SOHC_MShue's Avatar
Default Re: should i get my new block's deck resurfaced? (incredteg3)
well i have friends that can help me with the block. I just really am tired of the downtime. I'm an impatient biotch
Old Nov 22, 2004 | 02:24 PM
rioninja's Avatar
Just get yourself a straightedge and some feeler gauges and check it for warpage.
Old Nov 22, 2004 | 03:05 PM
PrettyLude's Avatar
just get it decked to ensure you are working on a straight platform
Old Nov 22, 2004 | 03:22 PM
alpha's Avatar
Do it. I did my block and head. It's a must IMO.
Old Nov 22, 2004 | 03:43 PM
SOHC_MShue's Avatar
Default Re: should i get my new block's deck resurfaced? (0x64)
should i do it even if my block checks out to be straight?
Old Nov 22, 2004 | 04:11 PM
Bailhatch's Avatar
if it's perfect, then ya just clean the hell out of it. It may not be, who knows
Old Nov 22, 2004 | 04:13 PM
alpha's Avatar
If all points of the deck surface turn out to be level/straight I wouldnt worry about it.
Old Nov 22, 2004 | 04:23 PM
Stewie's Avatar
Default Re: should i get my new block's deck resurfaced? (rioninja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rioninja &raquo;</TD></TR><TR><TD CLASS="quote">Just get yourself a straightedge and some feeler gauges and check it for warpage. </TD></TR></TABLE>
Old Nov 23, 2004 | 08:56 AM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">if it's perfect, then ya just clean the hell out of it. It may not be, who knows</TD></TR></TABLE>
yea i'll check it. I never really checked my other one because the studs were in the block. also if there are any tiny tiny scrathes on the deck surface should I be worried? It looked like there are some tiny ones where maybe the previous owner had razored off something to clean it. The block is very clean other than that.
Old Nov 23, 2004 | 12:09 PM
SOHC_MShue's Avatar
Old Nov 23, 2004 | 12:19 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 &raquo;</TD></TR><TR><TD CLASS="quote">If all points of the deck surface turn out to be level/straight I wouldnt worry about it.</TD></TR></TABLE>
Best info right here.
Old Nov 23, 2004 | 12:41 PM
SOHC_MShue's Avatar
Default Re: should i get my new block's deck resurfaced? (ladysman)
alright sounds cool. You guys know what the clearance is suppost to be? Like what size feeler gauge i gotta use?
absolut01gsr
Jun 4, 2008 04:55 PM
92EG8
12
Apr 30, 2008 04:30 PM
sivikvtec
Mar 16, 2007 10:47 AM
V8 BAIT
Jul 1, 2004 01:18 PM
YellowR2000x2
Sep 10, 2002 11:44 AM
