94 accord h22 swap problems, Help please
I just got my car up and running and i believe i have a bad knock sensor. Does anyone know if that would cause my car to bog, and feel like it has a lag to get to vtec? It seems like the car just falls on its face until vtec. Please help.... Thank you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-accord_94 »</TD></TR><TR><TD CLASS="quote">I just got my car up and running and i believe i have a bad knock sensor. Does anyone know if that would cause my car to bog, and feel like it has a lag to get to vtec? It seems like the car just falls on its face until vtec. Please help.... Thank you</TD></TR></TABLE>
check the wires on the injectors..make sure they are plugged in all the way...try using the knock sensor from your original f22 motor....make sure your oxygen sensor is good...make sure you have good spark plugs..make sure your vacuum lines are connected properly...make sure you have the right oil level...i had the same problem when i did my swap butit turned out to be a loose injector wire.
