raising compression using stock head gasket
Old Dec 28, 2001 | 11:48 AM
neumonik's Avatar
Default raising compression using stock head gasket
I want to raise the compression on my b18c5. It's bone stock with the exception of a cai. I was reading about using a stock head gasket and removing the rivets and using a layer from that.
Which layer to use? I read in one post that the outer layer is thinner then the middle... how true is that statement? Is there anyway I can calculate an estimated compression using measurements of the different layers?? I know I could do a compression test before and after but if it's not going to be significant (.2 or something) then I don't want to waste the time.
Thanks!
Frank
Old Dec 28, 2001 | 12:30 PM
RyanR's Avatar
Default Re: raising compression using stock head gasket (neumonik)
Remove the middle layer and use the two outer layers. This will raise the compression about .3.
Old Dec 28, 2001 | 10:32 PM
bojangs's Avatar
New User
Default Re: raising compression using stock head gasket (97TypeR_9)
it won't quite be .3 difference just by pulling the middle layer.. running a one-layer (bottom layer only) will yield closer to a .3 difference.. and remember, when torqueing with a thinner gasket you generally want to do it in more stages ( 4 or 5 opposed to 3) to insure that you're getting an even crush on the gasket..
Old Dec 29, 2001 | 09:52 AM
Katman's Avatar
.... I know I could do a compression test before and after but if it's not going to be significant (.2 or something) then I don't want to waste the time.
Thanks!
Frank
actually it's really not worth doing, you won't tell much of a difference with a thinner headgasket. I've tried that route and I'm sure the gain in higher compression is there, but you won't 'feel' a good gain with a thinner headgasket. I personally think that thinner headgaskets for B-series engines are overrated.
You're better off leaving your stock headgakset alone or just buying an aftermarket one (spoon/mugen).
The best way to raise compression is either buy going GSR head on your B18C5 or changing the pistons to something that has a higher dome.
good luck.
Old Dec 30, 2001 | 10:41 PM
Vtec integra's Avatar
or just shave your head
Old Dec 31, 2001 | 02:14 AM
gsrvx's Avatar
New User
Default Re: raising compression using stock head gasket (Vtec integra)
Make sure that if you get ur head milled...the person doing the work knows what he's doing.
Old Dec 31, 2001 | 10:03 AM
Crazydave's Avatar
Yeah I recommend the #2 Clipper
The #1 Clipper is too short and your head will be overcooled
the #2 works great
Old Jan 1, 2002 | 10:17 AM
Katman's Avatar
oh yeah you can do that, but even that has its problems. Correction of cam timing needs to be made if you mill a hea, especially when a head is milled down a lot.
Old Jan 15, 2002 | 12:45 PM
fsp31's Avatar
Default Re: raising compression using stock head gasket (Katman)
>>Correction of cam timing needs to be made if you mill a head, especially when a head is milled down a lot.<<
Is there a general rule with regards to cam timing and milling the head or installing a thinner gasket? At what point does milling the head for more compression become detrimental unless timing is advanced?
I vaguely remember a formula with regards to advancing the timing x.x degrees for every xx thousanths milled off the head. Is there such a formula? Thanks!
High Reved Racing
Jul 14, 2008 04:37 PM
petty$rep
Nov 11, 2006 02:20 PM
fastwanabe
Dec 6, 2004 01:29 PM
fastludeh22
Oct 14, 2002 01:52 PM
