Adding VAFC just to activate VTEC on a y7/y8 mini me?
I have a 99 civic with the stock y7 motor. I plan on doing the mini-me and I am going to use a y8 head, y8 automatic intake manifold along with my auto y7 throttle body, y7 harness and y7 ecu. Will the VAFC work with this setup just to activate VTEC? The reason I am doing this is that I already have all the parts and don't want to buy more stuff. I know the y7 ecu redlines at 7100 and the y8 redlines at 7200, but it's not like I ever run my car that high anyway because the motors stop making power a couple hundred rpms below. I just need to know if I can wire the VAFC into my ecu and wire the VTEC solenoid to the VAFC and set the crossover. Thanks
Help please. All I'm wanting to know is if the VAFC will work with my non-VTEC ecu and y8 VTEC head and will be able to set the VTEC.
no it will not work with ur non vtec ecu. because your ECU is not programed for it.
The VAFC only adjust when the sends the signal to engage vtec and the other adjustments that can be made
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">no it will not work with ur non vtec ecu. because your ECU is not programed for it.
The VAFC only adjust when the sends the signal to engage vtec and the other adjustments that can be made</TD></TR></TABLE>
Correct...you need an MSD RPM switch.
Just run the Y7 ecu, and run the solenoid to an MSD RPM switch...kicks on over a certain point, off at a certain point...kinda like a VTAK ECU!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">HAHA I finally beat u to a post bauley...
Yeah I was too busy whining about my shitty day.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">
Just run the Y7 ecu, and run the solenoid to an MSD RPM switch...kicks on over a certain point, off at a certain point...kinda like a VTAK ECU!</TD></TR></TABLE>
So you're saying instead of using a VAFC, all I really need is this MSD thing?Where can I pick up one of these MSD RPM switches and how much are they?
ATLien6
Engine Management and Tuning
Apr 14, 2012 01:59 PM
EK k kay
Nov 18, 2004 11:18 AM
