Need help on ECU trouble code
Old Nov 21, 2004 | 11:42 AM
gsrcivic619's Avatar
Default Need help on ECU trouble code
My car just threw a 91????? I cant seem to find what trouble code that is?? If anyone has any suggestions or answers please let me know. Should i disconect my battery and then try again? or what can i do? Thanx (99 Dx)
Old Nov 21, 2004 | 11:54 AM
Kamin's Avatar
Default Re: Need help on ECU trouble code (gsrcivic619)
no code 91 ive ever heard of, go check again.
Old Nov 21, 2004 | 11:56 AM
Default Re: Need help on ECU trouble code (Kamin)
should i disconnect the negative and then reconnect it and try again??????
=GAME='s Avatar
i think you read the light wrong.
Old Nov 21, 2004 | 11:58 AM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrcivic619 &raquo;</TD></TR><TR><TD CLASS="quote">should i disconnect the negative and then reconnect it and try again??????</TD></TR></TABLE>
no because that will erase the code.
try again.
Old Nov 21, 2004 | 08:18 PM
Anyone know why i would b e throwing a 91????? Can my ecu be bad?
Old Nov 21, 2004 | 08:19 PM
Ricey McRicerton's Avatar
If you really can't figure it out, Autozone will read your codes for you.
Old Nov 21, 2004 | 08:24 PM
Default Re: Need help on ECU trouble code (Ricey McRicerton)
i know how to check an ecu, but for some strange reason its throwing a 91. Should i get a REAL obd2 diagnostics machine to check it? instead of using the paper clip method??????
skill178
Sep 12, 2011 09:23 AM
mugenboi
Nov 2, 2007 05:12 AM
hatch96y7
May 11, 2007 06:15 PM
FuNkDrSpOt
Mar 24, 2007 01:22 AM
