? on installing aftermarket pistons
okay i know when u install OEM pistons they have an arrow and you put them in so the arrow points toward the timing belt. but on like JE and ENDYN pistons they dont have an arrow, so does that mean u can put them in either way ???
There should be relief cut out on the intake side of the piston.
The intake has larger valves so the pistons have larger pockets on that side.
I don't know if the pistons will contact the valves if you put them in backwards but don't risk it.
smokinsi
Jul 25, 2004 05:51 AM
