swap wiring help asap *pics*
Old Nov 21, 2004 | 09:26 AM
bambbrose's Avatar
Default swap wiring help asap *pics*
I just got my swap from HMO on friday, and I'm now finishing up the wiring and getting ready to throw it in my new hatch.
I added all the vtec wires and knock sensor already.
I'm using a 93 DX wiring harness.
After taking the b16 harness off, switching all the wiring, and putting the DX haness back on I'm left with a plug that don't have a location for. I can't find anything on my b16 that isn't plugged in.
It's located right under the intake manifold where the oil pressure sensor and those wires should be. It has 2 wires: red, yellow/black. I don't have any idea where it goes.
Can anybody help me with identifying the plug? what does it go to?
thanks guys, I appreciate your help
Old Nov 21, 2004 | 09:59 AM
Turbogixxer's Avatar
Default Re: swap wiring help asap *pics* (bambbrose)
Thats your purge control solenoid connecter.
Old Nov 21, 2004 | 10:03 AM
bambbrose's Avatar
cool thanks for the info, now what do I hook it up to on the b16 lol? There isn't a purge plug anywhere
Old Nov 21, 2004 | 10:18 AM
Default Re: (bambbrose)
You have to reuse the one off your civic
Old Nov 21, 2004 | 11:42 AM
bambbrose's Avatar
well **** that sucks. I got the hatch as a shell for $600, however no engine was included. There are a couple small parts that I need from the old engine, such as the evap purge, bitch pin, and some small things.
Old Nov 21, 2004 | 05:36 PM
Ransom's Avatar
you dont really need it...
Old Nov 21, 2004 | 05:41 PM
bambbrose's Avatar
will it throw a code without it? whats the side effects of no evap purge?
Old Nov 21, 2004 | 06:27 PM
locash's Avatar
No code will be thrown. It is basically there to minimize the amount of fuel vapor escaping to the atmosphere. Long story short, it won't affect driveability to a noticeable extent, ignore it for now.
Old Nov 21, 2004 | 11:26 PM
Katman's Avatar
Default Re: swap wiring help asap *pics* (turbogixxer)
(what he said)...
plugs into this black doohickey:
Old Nov 22, 2004 | 04:29 AM
GiT LaO'd's Avatar
Running a GSR motor...That would be for the IAB's...After you repin A20 to A17...
Old Nov 22, 2004 | 06:57 AM
Ransom's Avatar
Default Re: (jaybee)
dood it has nothing to do with the iabs
Old Nov 22, 2004 | 06:59 AM
GiT LaO'd's Avatar
I said if HE WAS RUNNING A GSR MOTOR...then that plug would be for the IABs...damn...
Old Nov 22, 2004 | 10:11 AM
Ransom's Avatar
o ic what your saying...after repinning you can use that as an iab plug..my bad.
gvrules
Feb 6, 2009 08:45 PM
r0guish
Apr 19, 2006 12:31 AM
jake1511
Nov 9, 2005 11:05 PM
It's*BOLO!!
Jan 3, 2003 07:38 PM
90civichbsi
Jul 10, 2002 03:00 AM
