96 Civic Hatch Main Relay Problem?
Everything is done, have the motor in, everyting hooked up, go to start it, and the fuel pump doesnt prime. From what Ive read its the main relay. I was trying to find some pictures on where it is located, but couldnt. Can you just replace the main relay? Also, when we put power the the yellow/grn wire on the fuel pump, its turned on, and we were able to start the car. But as soon as we took the wire off, it shut off. Any one have any info? Thanks in advance!!
main relay is under the drive side dash to the left of the steering column usually right around where the under dash fuse box is...ive had two main relays go out on me...just pop one out...pop the other one in and your done
Jcgbeasttube
Honda Civic (2006 - 2015)
Mar 19, 2018 10:07 PM
Just2Bar
May 19, 2015 03:59 PM
98typerar
14
Jan 25, 2014 03:34 PM
wambus
Feb 12, 2004 08:40 PM
