obd1 swap in an obd2 car
Old Nov 20, 2004 | 08:43 PM
v.i.gsr's Avatar
Default obd1 swap in an obd2 hatch
I have a 96 cx, with an 94 gsr swap. I would like to know if it is possible to convert it back to obd2. if it is, what would I need.
thanks in advance
Old Nov 21, 2004 | 02:40 PM
v.i.gsr's Avatar
Default Re: obd1 swap in an obd2 hatch (v.i.gsr)
bump
Old Nov 21, 2004 | 08:14 PM
v.i.gsr's Avatar
night bump
Old Nov 21, 2004 | 11:21 PM
Katman's Avatar
the easiest way to convert an OBD1 engine to work in an OBD2 car is by getting OBD2 B-series distributor, injectors, and alternator. And either run a JDM OBD2 ecu, or convert to OBD1. Avoid using a US OBD2 ecu because those ecu's look for the CKF sensor & 2nd 02 which your OBD1 engine does not use or have (CKF is integrated on the oil pump on US OBD2 engines).
or you can do it the semi hard way....
by repinning your distributor plugs to OBD1 dizzy , alternator, and injector plugs. Again, use a JDM OBD2 ecu or convert to obd1.
Old Nov 22, 2004 | 10:18 AM
v.i.gsr's Avatar
Default Re: obd1 swap in an obd2 hatch (K@man)
GOOD LOOKING K@MAN
mobeast808
Jan 26, 2025 09:18 PM
drunknmonkey18
Oct 23, 2004 08:32 AM
92civic_si
16
May 6, 2004 02:50 PM
