How do you read spark plugs?
Old Nov 20, 2004 | 05:47 PM
91TegLS's Avatar
Default How do you read spark plugs?
What's it mean when your spark plugs look like this?
Also my compression test resulted in:
#1 - 185
#2 - 190
#3 - 190
#4 - 195
So after a valve adjustment I think my engine shall be just fine for a good turbo.
PS: Car is a 1991 LS with 150k miles on original motor.
Note: If pic doesn't work still, try this: http://70.16.122.163:870/Plug.JPG
Modified by 91TegLS at 10:07 PM 11/20/2004
Old Nov 20, 2004 | 05:50 PM
the cartel
Guest
Posts: n/a
Default Re: How do you read spark plugs? (91TegLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91TegLS &raquo;</TD></TR><TR><TD CLASS="quote">What's it mean when your spark plugs look like this?
#1 - 185
#2 - 190
#3 - 190
#4 - 195
PS: Car is a 1991 LS with 150k miles on original motor.</TD></TR></TABLE> it means your fucked. i NEVER pulled ANYTHING that looked like a red x out of my motor
Old Nov 20, 2004 | 06:02 PM
91TegLS's Avatar
Default Re: How do you read spark plugs? (integrrrrrra)
dude it should work.. I'm hosting the damned thing lol
Old Nov 20, 2004 | 06:23 PM
SmurfDA's Avatar
From: I live in a town with Boston traffic, mass, united states
numbers look good, and plugs dont look bad
Old Nov 20, 2004 | 06:29 PM
LSvtec03's Avatar
Default Re: How do you read spark plugs? (93TealSi)
the color doesn't look bad, but i'm pretty sure it's bad that those specs are there.
Old Nov 20, 2004 | 09:41 PM
rovigian's Avatar
Default Re: How do you read spark plugs? (LSvtec03)
yeah a light brown or light grey color is good as far as i know, those specs don't look normal to me either...
Old Nov 20, 2004 | 09:42 PM
Greenery18's Avatar
I think those plugs look almost perfect. The first 2 rings are dark, meaning you have the right plug for your heat application, and the tip is light colored meaning you are getting a good air:fuel ratio burn(probably).
As for turboing with your setup, go for it You have decent compression #'s, but I still probably wouldn't go much over 7lbs boost.
janiscrulzz
12
Jan 10, 2012 12:14 AM
devnull
Aug 22, 2007 10:19 AM
The-LS
Feb 23, 2006 10:26 AM
LSVTEC 91 Civic
May 16, 2004 04:24 PM
mickey513
Feb 23, 2004 05:41 PM
