got a cod 43, fuel supply system
Old Nov 20, 2004 | 05:06 PM
SOHC_Brian's Avatar
Default got a cod 43, fuel supply system
car is a 89 civic std, with a 93 d16z6 motor and obd0->obd1 harness using a p28 ecu.
today the check engine lite popped up and i checked it and got a code 43, which is for fuel supply system. what do i do to repair this? i'm going to start by changing the fuel filter. do you guys think i should change the fuel pump also? never got this code before, so i'm not sure how to go about attacking it
Old Nov 20, 2004 | 05:43 PM
Cory man's Avatar
Default Re: got a cod 43, fuel supply system (lazyassbrian)
That code has to do with the heated 02 sensor. Swap out your o2 and Im sure that will fix it. HTH
Old Nov 20, 2004 | 05:45 PM
SOHC_Brian's Avatar
Default Re: got a cod 43, fuel supply system (Cory man)
i have one laying around from a b18c motor, would that work?
hatchet_honda
Jul 26, 2010 08:54 PM
str8JDMteggy
Sep 29, 2006 08:27 AM
cincispeedemon
Nov 22, 2004 05:51 PM
RoAnSa
Jun 30, 2003 04:37 PM
oO
Apr 10, 2003 07:03 AM
