Should I torque my DC header? What should I use to get grease stains out?
Old Nov 20, 2004 | 03:33 PM
B18Redline's Avatar
Default Should I torque my DC header? What should I use to get grease stains out?
I just put on a dc sports header. Everything is done except I did not bolt the top bolts to the block because it got dark outside. My question is do I need to put the bolts on with a torque wrench or can I just tighten without using a torque wrench?
Also how should I clean the header before I turn the car on. I heard that if you don't clean a header after install, permanent fingerprint marks will occur.
Thanks!
Old Nov 20, 2004 | 03:54 PM
W.O.P.'s Avatar
Default Re: Should I torque my DC header? What should I use to get grease stains out? (Redline07)
torque wernch is your friend and use rubbing alcohol. if you cant get ahold of a torque wrench then tighten it gudntite
Old Nov 20, 2004 | 04:34 PM
boosted k20's Avatar
Default Re: Should I torque my DC header? What should I use to get grease stains out? (chirpin_3rd)
u need to torque the bolts down to 24ft-lbs. also need to torque it in cross hatch pattern : start from the middle and work ur way out. if u dont have a torque wrench, just tighten it by hand until it's tight. then give it about a 1/2 turn again
Old Nov 20, 2004 | 06:28 PM
LSvtec03's Avatar
Default Re: Should I torque my DC header? What should I use to get grease stains out? (boosted k20)
eh, it's not really a big deal if your header isn't torqued. just tighten it enough so you know it's not gonna fall off or anything. it's probably not even that important to do the criss-cross pattern either, but i'm **** so i do it anyway.
Old Nov 20, 2004 | 08:57 PM
GeeReg's Avatar
Use one if you have it. All too often there's a "I broke a header bolt/stud!! How can I get it out?" thread.
Old Nov 20, 2004 | 10:28 PM
BrianZ's Avatar
Default Re: Should I torque my DC header? What should I use to get grease stains out? (LSvtec03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">eh, it's not really a big deal if your header isn't torqued. just tighten it enough so you know it's not gonna fall off or anything. it's probably not even that important to do the criss-cross pattern either, but i'm **** so i do it anyway.</TD></TR></TABLE>
The reason you want to torque the header is to prevent to much stress (or bolt stretch) and to create even pressure across the flange. If you just tighten to feel you may create leaks.
Old Nov 21, 2004 | 08:38 AM
sabotage7's Avatar
id torque it if i were you, in the criss cross pattern as suggested.....and yes, rubbing alcohol is good like mentioned.... make sure you clean it before you turn the car on for the first time to prevent finger prints. have fun!
Old Nov 21, 2004 | 11:20 AM
xprohx's Avatar
I think too much
Default Re: Should I torque my DC header? What should I use to get grease stains out? (sabotage7)
I didn't torque it down, but you should if you have the tools.
tpot90
Mar 15, 2009 06:31 AM
NSfit
Honda Fit
Jan 2, 2009 07:57 AM
DLjunky
Oct 10, 2007 07:18 PM
OpTiMo MoToR
Honda Civic (2001 - 2005)
11
Nov 29, 2006 08:04 PM
MintyDip
Aug 2, 2001 06:52 PM
