Please check the inside wall of your tires - FYI
Old Dec 28, 2001 | 07:05 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Please check the inside wall of your tires - FYI
I had the urge to rotate my own tires this holiday season. I found out that the sidewall of one tire was completely cracked. It was about 10 inches long and the steel belts were showing. My thoughts was, this could have blown any time. The outside sidewall was in pefect condition, and show no signs at all, and there was still some meat on the treads too. There was no lost in air, so I really would not have known.
Lucky I was not on the road. Could have gotten hurt or killed if the tires blow.
Therefore, PLEASE also check the condition on the inside of your tires too.
Old Dec 28, 2001 | 07:15 AM
Spade's Avatar
Default Re: Please check the inside wall of your tires - FYI (GoLowDrew)
Thanx bro.............tires are good just checked them last night.
Old Dec 28, 2001 | 03:07 PM
94civicx's Avatar
New User
had the same exact problem. My front right tire looked perfect on the edge facing the fender wall, and when I had the oil change and the car was lifted, about 3 inches into the tire facing the engine was complete steel. The scary thing is that I left on a road trip to Phoenix with my wife the day before and I was going 90+. All it took was that tire to blow being a steering tire and I would have been grass
Old Dec 28, 2001 | 04:23 PM
markaria's Avatar
is your car lowered with negative camber out of wack?
If not, then you could have one of 2 problems:
1)check your alignment
2)if your lower control arm bushing(s) is in bad shape it will naturally cause your car to have bad alignment-happened to mine and I wore out the inside of my passenger front tire within 5000 miles
Old Dec 29, 2001 | 09:56 AM
94civicx's Avatar
New User
Default Re: Please check the inside wall of your tires - FYI (markaria)
I ended up buying an Ingalls Camber Kit
Old Jan 2, 2002 | 12:53 PM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Re: Please check the inside wall of your tires - FYI (94civicx)
That make sense since the negative camber put more stress on the inside tire wall. But just freaky how the sidewalls just die like that. I still think it's a tire quality issue.
BTW, did you happen to get "cheap" tires?
AJ@tirerack.com
Oct 31, 2019 04:57 AM
vladd
Feb 23, 2009 09:39 AM
vtecsi00
May 27, 2008 11:12 PM
easyFOsheezy
Apr 7, 2006 01:24 PM
SIXTYdashONE
Jan 29, 2003 04:05 PM
