can someone help me out
Old Dec 28, 2001 | 06:27 AM
cornbread's Avatar
Default can someone help me out
I figured there must be some gear heads in this forum so I’m goanna post this question here. I did post on the civic, tech & Integra forum and it seam no one can help me with this problem
I traded my Acura legend for it. All and all the car pulls hard and it’s a nice car. It has a few visible performance mods headers, CAI, and cat back. But there is one problem, when the car idles it bounces from 1000rpm to 2000rpm back and forth. Does any one know what could be causing it to idle that way? The guy I got the car from bought it from this guy in NY and he has no idea if he did any motor work to it. Any info will be greatly appreciated
Old Dec 28, 2001 | 06:32 AM
Willard's Avatar
Default Re: can someone help me out (smokeeeLSR)
A leaky near the throttle body. Get a new throttle body gasket and see if that fixes it.
Will
Old Dec 28, 2001 | 06:35 AM
cornbread's Avatar
Default Re: can someone help me out (Willard)
I was thinking a might need a new idle speed motor (IAC it think)
Do you think that could be a problem too.
Old Dec 28, 2001 | 06:42 AM
Knightsport's Avatar
El Chico
25 Year Member
Community Builder
Community Influencer
My Prelude did it all the time after I fixed it up.
It never hurt anything though.
Old Dec 28, 2001 | 06:45 AM
SOHCArchangel's Avatar
Default Re: can someone help me out (Knightsport)
fast idle valve is bad, just take it off tap and plug the one hole and bypass the coolant you will be straight
Old Dec 28, 2001 | 06:53 AM
cornbread's Avatar
Default Re: can someone help me out (SOHCkordVTEC)
can you ansure with more details please. I'm a little confused.
Thanks
Old Dec 28, 2001 | 07:14 AM
remove your fast idle valve at the bottom of your throttle body
bypass all coolant lines away from the throttle body
remove throttle body and at the bottom there is a hole, tap the hole with a die and plug it with the appropriate size bolt, new gasket and re-install
Old Dec 28, 2001 | 07:17 AM
cornbread's Avatar
thanks man
EnviedByMany
Oct 21, 2010 07:23 AM
Team Freddy
Jan 16, 2008 06:35 PM
fishman
Aug 15, 2002 07:05 PM
FourthGenHatch
Apr 29, 2002 11:08 AM
cornbread
Dec 28, 2001 09:59 AM
