Throwing codes on 2000 D16y8 - was auto, now manual trans car
Old Nov 20, 2004 | 11:36 AM
atc5's Avatar
Default Throwing codes on 2000 D16y8 - was auto, now manual trans car
Guys, I need some serious help here....I have a 1999 EK that had a USDM type r motor in it. I sold the ITR motor to a guy and he gave me his 2000 automatic d16y8 motor as part of the deal.
I am running a manual trans now, manual ecu, automatic wiring harness, manual intake manifold and I'm throwing two codes, most notably code 14, the IACV. I'm also throwing code 65, a secondary o2 sensor. The o2 can be easily remedied but the IACV is driving me nuts. All of the wiring is correct to the ecu and the intake manifold I just installed today.
So that said, I need help...I have no idea what is causing this IACV code to be thrown and I need to get the car smogged to sell it to a very patient buyer.
Any d series masters out there now where the problem lies?
Thanks-
Old Nov 20, 2004 | 11:42 AM
civictildeath's Avatar
Default Re: Throwing codes on 2000 D16y8 - was auto, now manual trans car (atc5)
i dont know but bump for you cause alot of people like to follow me and try to get me when im wrong
steve0unce's Avatar
did you do the iacv 3 to 2 wire fix?
Old Nov 20, 2004 | 11:45 AM
atc5's Avatar
Default Re: (steve0unce)
on the 2000, the iacv is a 3 wire....weird but true. I compared it to another manual trans 2000 d16y8 side by side today and it was a 3 wire.
Old Nov 20, 2004 | 11:47 AM
BukakkEK9's Avatar
Im no D series master but if im not mistaken the automatic Y8 has a Three wire AIC plug no? if thats the case, your manual ecu is reading it wrong and u have to get rid of the orange wire thats in there and re pin the other two, if u have a service manual look where the other two wires go. if this isnt the case then im sorry but thats the only thing i can think of that would cause it other than a bad AIC valve.
Old Nov 20, 2004 | 12:35 PM
steve0unce's Avatar
are you talkin about the wire harness is 3 wire?
Old Nov 20, 2004 | 12:40 PM
ek9hatch0WN3R's Avatar
yeah the orange wire you wouldnt use, but im not sure if that helps you out much.
Old Nov 20, 2004 | 01:09 PM
atc5's Avatar
Default Re: (ek9hatch0WN3R)
yes, the iacv harness off my wiring harness is a 3 plug AND the harness on the iacv on the back of the intake manifold is a 3 pin.
I have confirmed on another 2000 d16y8 manual trans car that the plug and pin are both 3.
Old Nov 20, 2004 | 01:19 PM
huntarrr's Avatar
Default Re: (atc5)
What about the intake manifold? Is it an automatic or the manual? On a manual intake mani, the IACV is ON the manifold. For the auto, the IACV its integrated with the TB.
Old Nov 20, 2004 | 01:59 PM
atc5's Avatar
i just swapped in a manual intake manifold today. You are right, the IACV is on the manifold.
Old Nov 20, 2004 | 02:07 PM
steve0unce's Avatar
so meaning you need to do iacv fix right..
Old Nov 20, 2004 | 02:10 PM
atc5's Avatar
why do i need to do a fix when the engine harness AND the iacv harness are both the 3 pin?
There isn't a 2 wire in either of them....
Anyone with a 2000 ex go look at their IACV valve and tell me if it's a 3 wire like mine is? The intake manifold I have is a P2K and is from a manual 2000 ex manual car...so I have no idea why I should do the IACV fix when it's 3 and 3.
Is my only option to find ANOTHER intake manifold with a 2 pin IACV and swap that in?
Old Nov 20, 2004 | 08:16 PM
FredoTheChimp's Avatar
Default Re: (atc5)
Bump for a great guy help him fix it please .
Old Nov 20, 2004 | 09:22 PM
ej0513's Avatar
Default Re: (FredoTheChimp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoTheChimp &raquo;</TD></TR><TR><TD CLASS="quote">Bump for a great guy help him fix it please .</TD></TR></TABLE>
for real! get this fixed for Alan.. good guy!
Old Nov 20, 2004 | 10:38 PM
atc5's Avatar
thanks guys...ok, so if I understand it right, I need to get a 2 wire IACV and simply bolt that into the intake manifold on the car and wire that in, correct?
I think i have to move a pin in the ecu too, yea?
Thanks-
Old Nov 20, 2004 | 10:43 PM
steve0unce's Avatar
correct...but the 2wire should be on the manifold already
Old Nov 20, 2004 | 10:52 PM
atc5's Avatar
ok, but the manifold I have the 2 wire is not on it
now what?
Old Nov 21, 2004 | 12:30 PM
atc5's Avatar
Default Re: (atc5)
bump for options
Old Nov 21, 2004 | 12:33 PM
steve0unce's Avatar
if you can give a visual it would help...then we can work from there
Old Nov 21, 2004 | 12:35 PM
igo4bmx's Avatar
ok
first u said u have an auto engine harness?&gt;
if so you need a 2 wire plug to connect to the 5 speed 2 wire IACV
second, the pin out for the IACV is different for an auto and manual car
good luck
Old Nov 21, 2004 | 12:41 PM
atc5's Avatar
got it...
ok, i think i have the wrong intake manifold then.
anyone have a picture of the manual ek intake manifold iacv?
Old Nov 21, 2004 | 12:56 PM
steve0unce's Avatar
Default Re: (atc5)
tim73
17
Jan 11, 2015 08:08 AM
hondaeg95
Jun 8, 2008 11:39 AM
overboostedrex
Feb 22, 2006 09:46 AM
masterexpert
May 31, 2005 04:13 AM
dubniK
Jun 12, 2004 08:49 PM
