PSI amount for ls motor
Old Dec 28, 2001 | 04:42 AM
turboteg96's Avatar
Default PSI amount for ls motor
Hi everybody, I will be building up my motor for turbo this includes new rods and pistons(Overbore) I want to know the best compression ratio to be ran for the maximum amount of boost. like if I run 8.5:1 can I run 15 psi of boost SAFELY. Without blowing up the motor. My car is a 96 Acura Integra RS with the 1.8L
Feedback appreciated
[Modified by turboteg96, 1:43 PM 12/28/2001]
Old Dec 28, 2001 | 05:32 AM
rtype11's Avatar
Default Re: PSI amount for ls motor (turboteg96)
well the first problem you run into is the octane barrier, depending where you live int the sates your gas is crap. consider that for every 4psi you can assume a rise in CR by 1, 15PSI is roughly an additional 4 dynamic compression points. your 8.5:1 is now 12.5:1 with very high cylinder pressures, i would not run anything less than pure 94 octane without any of that corn oil crap. Now if you build a lower PSI motor like 9PSI you can stil have a decent 9.2 (LS) or like 10:1 motor and still run pretty safe with a great bottom end.
cheers - oh yeah you should have searched for this first.
Old Dec 28, 2001 | 09:02 AM
DIRep972's Avatar
Smarter than you
9:1 compression is perfect for boost.. Just stick with 9:1 you can run 12psi safely on pump gas and then run 15psi on race gas.. appropiate tuning of course
Old Dec 28, 2001 | 09:49 AM
turboteg96's Avatar
Thanks, I just wanna be safe and not blow up my motor at the same time.
Bseriescivic5
Nov 24, 2006 12:26 PM
Scubster
Dec 16, 2004 10:54 PM
1SIKCRX
Oct 13, 2003 10:04 PM
Spoold_R
Jan 11, 2003 02:36 PM
mrblur
Oct 23, 2002 12:46 PM
