wheel offset for NSX brake calipers?
Old Nov 19, 2004 | 05:18 PM
volkdlr's Avatar
Default wheel offset for NSX brake calipers?
those of you that have NSX brakes on your car, what size wheel are you using and what offset? I would like to stay with 15" but have no clue on the offset.
Old Nov 19, 2004 | 09:36 PM
Dueceification's Avatar
Default Re: wheel offset for NSX brake calipers? (volkdlr)
I didnt know u can put nsx brakes on a civic. I knew u could do it on a prelude.
Old Nov 19, 2004 | 10:30 PM
Dengar's Avatar
Default Re: wheel offset for NSX brake calipers? (93b16hatch)
you can put them on gsr brake setups. pm slooogsr i know he has them on his gsr with rota c8s but i don't know if they are 15 or 16.
Old Nov 21, 2004 | 12:59 AM
Kengs's Avatar
15x7 TE37 (43mm offset)
Old Nov 21, 2004 | 03:23 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by volkdlr &raquo;</TD></TR><TR><TD CLASS="quote">those of you that have NSX brakes on your car, what size wheel are you using and what offset? </TD></TR></TABLE>
well, offset doesn't matter so much as spoke design. you could have more then enough offset, but the outer part of the spoke where it meets the wheel may not have enough clearance. as far as wheels, i run a gaggle of different ones
FD RX7 (16x8. +50)
steelie (15x6.5, +45)
steelies with hubbies (stealth mode)
TE37 (15x7, +45)
sorry, like this shot with the te's...
Kosei K1 (15x7, +38)
RSX wheels (16x6.5, +45? fitment was soooo friggin close to the caliper carrier, but it cleared)
custom machined 15x8.5's
man, wow has my car changed over the years
Old Nov 21, 2004 | 09:00 AM
volkdlr's Avatar
Default Re: wheel offset for NSX brake calipers? (rodney)
ThankYou for the info!
Old Nov 22, 2004 | 06:42 PM
cxSHOE's Avatar
rodney
damn nice set of wheels you've gone through. what no spoons??? come bro lets see them..
Old Nov 22, 2004 | 06:53 PM
ek9hatch0WN3R's Avatar
yeah some guy just a day or two ago was having fitment problems with his NSX brakes into his civic, so hopefully he'll chime in to help ya out too.
Old Nov 22, 2004 | 07:57 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: wheel offset for NSX brake calipers? (Dengar)
actally, not JUST gsr brakes, cause there the same as all 94-01 Integra brakes (-R). NSX calipers will go on, with the righ setup, the knuckles of any 94-01 integra, and 92-00 Civics (92-95 the EX/SI with ABS only, 96-00 EX and 99-00 Si only).
i heard a +40 with a 6" wide wheel will do it, someone wanna back me up?
Old Nov 22, 2004 | 08:30 PM
dantastic's Avatar
spoke design is also key. my roomate had racing hart T6, 18x7.5 +42 and they cleared his front brakes on his V6 accord fine b/c there was very little lip and the spokes were far towards the outside of the rim. when he switched to C2's (exactly the same size), the spokes went inwards for more lip and less brake clearance. he needed 5mm spacers up front to clear his brakes.
Old Nov 23, 2004 | 03:52 AM
Rodney's Avatar
Default Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">spoke design is also key.</TD></TR></TABLE>
Old Nov 23, 2004 | 04:36 AM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: (rodney)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodney &raquo;</TD></TR><TR><TD CLASS="quote">
Ha ha, you said "gaggle"
Old Nov 23, 2004 | 06:52 AM
josh green's Avatar
so what all is needed for the NSX brake conversion? I have a eg hatch with itr 5 lug swap. Do you swap the rotors as well as the calipers?... ill search
Old Nov 23, 2004 | 07:10 AM
Rodney's Avatar
Default Re: (josh green)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by josh green &raquo;</TD></TR><TR><TD CLASS="quote">so what all is needed for the NSX brake conversion? I have a eg hatch with itr 5 lug swap. Do you swap the rotors as well as the calipers?... ill search</TD></TR></TABLE>
it is easy for you my friend:
step 1: unbolt itr caliper
step 2: bolt on nsx caliper
step 3: enjoy!
*of course you have to bleed, don't anyppost saying they crashed my car without bleedig the brakes
Old Nov 23, 2004 | 07:57 AM
Nova_Dust's Avatar
Are NSX calipers 4 pot? If you upgrade to NSX calipers, will ITR MC be sufficient enough for it?
Thanks
Old Nov 23, 2004 | 08:28 AM
Rodney's Avatar
Default Re: (Nova_Dust)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nova_Dust &raquo;</TD></TR><TR><TD CLASS="quote">Are NSX calipers 4 pot? </TD></TR></TABLE>
no sir, they are 2 piston.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nova_Dust &raquo;</TD></TR><TR><TD CLASS="quote">If you upgrade to NSX calipers, will ITR MC be sufficient enough for it?</TD></TR></TABLE>
yes, an itr master is fine, as well as a 15/16 civic master as well.
Old Nov 23, 2004 | 08:40 AM
95cxh22a's Avatar
so i have a 95 cx with 94 integra discs all around. i put all the arms and everything off the integra. will the nsx calipers bolt right up to a four lug setup? i run a 15x7 kosei racing k1 ts. i think the offset is 40.
Old Nov 23, 2004 | 08:56 AM
delslow94's Avatar
Default Re: (95cxh22a)
the wheels you need to search for have a thing called "high disc" and is what everyone keeps talking about with the spokes being far out towards the lip. this will allow for the clearance...does anyone know what would need to be done for a del sol vtec (94') to make them fit...i think the suspension is the same as the gsr but am not sure. thanks
Malakai
Apr 4, 2012 07:41 PM
MessGSR
Honda Civic (2006 - 2015)
15
Dec 8, 2007 07:32 AM
A.S.I.M.O
Oct 4, 2006 02:52 PM
tranzvision
Apr 10, 2006 09:40 AM
noob with an RS
Jun 11, 2005 11:14 PM
