Clicking while in boost at around 6k-6500 rpm?
you can get detonation at 1psi if things aren't running right... the JRSC boys get tip in detonation.. unless they came up with a miracle cure... lay off the boost until you figure out what it is..
are you running lean around that rpm? what does your EGT or air/fuel look like at that point.. EGT's shooting up? air/fuel leaning out? is your timing advanced,retarded or stock? whats your fuel setup?
post your performance related mods.. we need more info..
