What trannys are possible for a b18b ls swap?
Old Nov 19, 2004 | 07:25 AM
Tapen00n's Avatar
Default What trannys are possible for a b18b ls swap?
i know the bore and stroke should have something to do with the pan size so i was wondering if the b18b tranny is interchangeable with all the other b series trannys
Old Nov 19, 2004 | 07:30 AM
VTC_CiViC's Avatar
Default Re: What trannys are possible for a b18b ls swap? (Tapen00n)
B18C, B16/17, basicaly everything but the CRV trans..
magicksdc2's Avatar
yes, all b-series transmissions are interchangeable. id recommend a GSR tranny if you want mildly improved gearing, or a b16 if you are looking for a little more, but are willing to sacrifice gas mileage on the highway.
Old Nov 19, 2004 | 07:34 AM
Tapen00n's Avatar
Default Re: (MGXcoupe)
ill prolly go with the b16 thanks for your help guys
Old Nov 19, 2004 | 03:15 PM
noahblkmale's Avatar
Default Re: (Tapen00n)
get the gsr tranny its the both of best worlds u not gonna like riding around in v tec all day and dumping gas money remember we run off of 93 or higher so whats that 240 a gal
Old Nov 19, 2004 | 03:18 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (noahblkmale)
wtf are all you guys saying? no, not all B-series trannies are interchangeable depending on what car the motor and tranny is going into.
Old Nov 19, 2004 | 03:33 PM
slambedcivic's Avatar
Default Re: (AzntaggeR)
providing you get the propen conversion kits, they are... with the exception of the 91 Si prelude b series tranny
Old Nov 19, 2004 | 03:46 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (slambedcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slambedcivic &raquo;</TD></TR><TR><TD CLASS="quote">providing you get the propen conversion kits, they are... with the exception of the 91 Si prelude b series tranny</TD></TR></TABLE>
finally, someone says it .
Old Nov 19, 2004 | 03:52 PM
JCritt's Avatar
ls tranny with a new 5th gear
Old Nov 19, 2004 | 07:28 PM
Default Re: (khaa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khaa &raquo;</TD></TR><TR><TD CLASS="quote">ls tranny with a new 5th gear </TD></TR></TABLE>
i think youve got it backwards... its a b16 or gsr tranny with a ls 5th gear... i could be wrong tho
Old Nov 19, 2004 | 07:54 PM
Gordon_B16's Avatar
Do your self a Favor and get the JDM ITR tranny u get the LSD and the 4.7 final Drive, and that's all she wrote!
Old Nov 19, 2004 | 07:57 PM
Dengar's Avatar
i think youve got it backwards... its a b16 or gsr tranny with a ls 5th gear... i could be wrong tho</TD></TR></TABLE>
yeah he did have that backwards. The gas mileage is not that much different between trannies. i have a jdm itr tranny with is basically the same gearing as a b16 and i get between 28-32 mpg with a gsr swap.
Old Nov 20, 2004 | 03:17 AM
Default Re: (Dengar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dengar &raquo;</TD></TR><TR><TD CLASS="quote">
yeah he did have that backwards. The gas mileage is not that much different between trannies. i have a jdm itr tranny with is basically the same gearing as a b16 and i get between 28-32 mpg with a gsr swap.</TD></TR></TABLE>
the only thing different is the 5th gear, right? i know i checked usdm hype r with the usdm B16 trannys and they were identicle to each other with the exception of the 5th gear... does this hold tru with the JDM piece?
Old Nov 20, 2004 | 10:56 AM
Dengar's Avatar
the only thing different is the 5th gear, right? i know i checked usdm hype r with the usdm B16 trannys and they were identicle to each other with the exception of the 5th gear... does this hold tru with the JDM piece?</TD></TR></TABLE>
I think the usdm itr tranny has either a 4.4 or 4.7 final drive, the jdm itr has a 4.8 final drive as i was told from the guy who i bought the car from.
either way the gears are short as hell and i have lsd.
Old Nov 20, 2004 | 11:07 AM
92talon4evr's Avatar
just as long as you dont use an LS tranny...gears are just too long IMO...usdm ITR is the only way to go
Old Nov 20, 2004 | 02:57 PM
Default Re: (92talon4evr)
i like my LS trans..... but i just put a hole in teh casing of it
i just scored a GSR tranny for 300
Old Nov 20, 2004 | 04:20 PM
Stinkycheezmonky's Avatar
Suspetise...
Holy ****. This is just a wealth of misinformation. JDM ITR tranny has a 4.78 FD, USDM ITR tranny has a 4.4 FD. That is the truth. Check out this page if you have questions about the ratios, as there was way too much **** for me to correct personally: http://www.hondaswap.com/forum...29829
Not all B-series trannies are interchangeable, as some are Hydro and some are Cable. There are conversion kits I think, but I don't see how that'd be worth it unless you were starting with a car that had a cable tranny.
To the original poster, is your engine a stock B18B or LS/VTEC? Either way, your redline is going to be pretty low, so an ITR tranny of either country is going to be questionable for highway driving. Use this to calculate, all you need to know is redline and overall tire diameter: http://www.autocrossing.com/cgi-bin/gearcalc.cgi FWIW, I have a stock B18B in my hatch right now, and I've been thinking of different trannies to swap in. The JDM ITR is simply too much. The car will be a daily driver/HPDE/track ***** to give you an idea of it's purpose.
Old Nov 20, 2004 | 05:06 PM
Slopoke's Avatar
Default Re: (sscguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sscguy &raquo;</TD></TR><TR><TD CLASS="quote">Holy ****. This is just a wealth of misinformation.</TD></TR></TABLE>
Lol, I guess you felt like adding to it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sscguy &raquo;</TD></TR><TR><TD CLASS="quote"> JDM ITR tranny has a 4.78 FD, USDM ITR tranny has a 4.4 FD.</TD></TR></TABLE>
Only the '98-up jdm itr tranny has the 4.7fd, the '96-'97 has the 4.4fd.
Old Nov 20, 2004 | 05:29 PM
ek9hatch0WN3R's Avatar
Default Re: (Slopoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke &raquo;</TD></TR><TR><TD CLASS="quote">Lol, I guess you felt like adding to it.</TD></TR></TABLE>
omg, you just 0WN3D him! ahhaahahah
Old Nov 20, 2004 | 05:30 PM
Default Re: (ek9hatch0WN3R)
seriously though guys, dont start throwing out things unless you know for sure that its factual information or at least say that youre not sure about it. lying is not JDM at all.
Old Nov 20, 2004 | 06:11 PM
Suspetise...
True, I did forget about that, but I figure that tranny is less common anyway. Also, I was more trying to correct the 4.8 JDM FD comment, which is just entirely incorrect, not just something omitted. I don't know if that's necessarily considered misinformation.
lshondaeg
May 9, 2008 11:53 AM
eL
Feb 15, 2007 10:56 AM
num1rbffan
Apr 25, 2006 04:08 PM
Dorikamu
Nov 6, 2002 04:09 AM
