Do i need an ITR exhaust cam
Old Dec 27, 2001 | 08:49 PM
speedymon's Avatar
Default Do i need an ITR exhaust cam
Did a search and nuthing specific. I have a 96 GSR and i want to get a CTR intake cam. Do i need an ITR or CTR exhaust cam? I see everyone else upgrading both.
Old Dec 27, 2001 | 09:38 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: Do i need an ITR exhaust cam (speedymon)
ITR/CTR are the same exhaust cam. (at least the 2001 ITR is)
Old Dec 27, 2001 | 10:16 PM
dohc_Cx's Avatar
New User
Default Re: Do i need an ITR exhaust cam (B18C-EJ1)
i think he meant that could he use the gsr exhaust cam, or at least that's what i think he meant..
Old Dec 28, 2001 | 01:12 AM
speedymon's Avatar
Default Re: Do i need an ITR exhaust cam (rACEr_b_O_y_)
Yes that is what i meant. I think i heard that the exhaust cam was only good for 1 hp or something i don't know. Just wanted some opinions. And yes i knew the CTR and ITR exhaust cams were the same.
Old Dec 28, 2001 | 06:04 AM
WAFFLES's Avatar
You don't need the exhaust cam. You can use the intake cam only and your gsr ex. cam. Some people just like to have the pair together. I don't know if it's worth the extra change that it will cost you.
Old Dec 28, 2001 | 01:57 PM
Charles B.'s Avatar
Default Re: Do i need an ITR exhaust cam (WAFFLES)
I think "non-R" intake cams(B-series) are they same as the R exhaust cam. So if you have a GSR, I think you can use the GSR intake cam as your exhaust cam and either the CTR or ITR as your intake cam. Correct me if I am wrong.
Also, I heard that the ITR exhaust cam along with your stock intake cam is good for turbo.
[Modified by SuperDuperEG, 11:35 PM 12/28/2001]
Old Dec 28, 2001 | 02:03 PM
speedymon's Avatar
Default Re: Do i need an ITR exhaust cam (SuperDuperEG)
I think "non-R" intake cams are they same as R exhaust cams. So if you have a GSR, I think you can use the GSR intake cam as the exhaust cam and either the CTR or ITR as your intake cam. Correct me if I am wrong.
What? Can someone back that up? I've never heard that before.
Old Dec 28, 2001 | 05:10 PM
evo's Avatar
evo
New User
i d't think u can use the GSR intake cam as your exhaust cam, if u put them together u can see IN cams is slight longer. unless u modify it.
Old Dec 28, 2001 | 07:25 PM
rioninja's Avatar
I've heard that this can be done as well. I can never remember to test fit it though when i have my cams out. True, its a little longer but only for the distributor. . . wouldn't there be enought room on the exhaust side? might be as simple as modifying the plastic cam plug.
Old Dec 28, 2001 | 11:43 PM
HybridCoupe's Avatar
in a b16a is it worth changing out the cams to 01 ITR cams....and a ITR intake manifold...how much extra power will that produce....?
Old Dec 29, 2001 | 09:34 AM
Katman's Avatar
lol..no you CANNOT put a DOHC VTEC intake cam on the exhaust side.
First of all the lobes are setup differently on the exhaust cam and the other thing is, the distributor key slot - there is NONE on the exhaust cam nor is there room to make one! so yah, it won't worky.
as far as the ITR exh. cam and stock intake cam for turbo setups, I heard that as well, is a good cam combo since turbo's work more off the exhaust side of the engine, having a bigger exhaust cam and smaller intake it's something worthy to try out...
[Modified by Katman, 10:34 AM 12/29/2001]
ej8b16a2
17
Jan 25, 2011 04:08 PM
redDAinteg
Apr 25, 2007 09:10 AM
lo0nY
Jan 19, 2006 05:31 PM
red_crx
Feb 19, 2005 06:05 PM
