Lights dimming???interior and headlight???
Old Nov 19, 2004 | 01:32 AM
foonk's Avatar
Default Lights dimming???interior and headlight???
cant seem to find the problem, just bought a EK 98 and the interior and exterior lights dim periodically. At idle it seems as if the engine is about to die......what could the problem be?
already has new battery and alternator is perfect.
Old Nov 19, 2004 | 03:09 AM
whole9's Avatar
Default Re: Lights dimming???interior and headlight??? (foonk)
Um it might not be grounded properly. but I don't know could be other things also... Someone on here might tell you what exactly to do to fix it, or link you up. Have you tried searching?
Old Nov 19, 2004 | 03:59 AM
93CivicSI's Avatar
Adjust your idle so that it does not settle at such a low idle
Old Nov 20, 2004 | 08:28 PM
jayare05's Avatar
Default Re: Lights dimming???interior and headlight??? (93CivicSI)
how new is the alternator? i had the same problem i used to have a paseo.. the headlights used to dim when i came to a stop and the heater wouldnt blow as hard when i wasnt on the gas.. If your alternator is fairly new check the tension on the belt.. but im pretty sure it has somethin to do with ur alternator.. if it wasnt grounded properly they wouldnt work at all..
venomzz
15
Nov 4, 2024 08:45 PM
CR3X
Mar 12, 2008 07:17 PM
EKRacer
18
Feb 6, 2006 03:53 PM
Layziebtnh055
May 3, 2004 03:15 AM
sackdz
Jul 6, 2001 08:50 PM
