IMPORTANT: Limiter at 6900 UPM but only in fifth gear! Whats wrong?
Old Nov 19, 2004 | 12:30 AM
agratise's Avatar
Default IMPORTANT: Limiter at 6900 UPM but only in fifth gear! Whats wrong?
Hi,
we builded up another turbo charged B16A2 Del Sol and used Chrome for the Dyno! After everything was perfekt we found out that the car stops injecting fuel at 6900 rpm with low or middle gas and with WOT it stops injecting fuel at 7500 upm! In both cases the car starts injecting fuel again 500rpm below the rpm when it stops injecting! I thought it could be the speed limiter but i changed it to 190mph and still the same problem! Even when i deactivatet it! Could it be the HKS Blow off valve? But i'm pretty sure that it is a electronic problem!!! Its only in Fifth gear, at a speed of about around 100miles!
Please help i got 12 hours left to solve the problem :-(
Thanks a lot!
Philip
Old Nov 19, 2004 | 12:35 AM
leed's Avatar
Default Re: IMPORTANT: Limiter at 6900 UPM but only in fifth gear! Whats wrong? (agratise)
could you post a link to your bin?
Old Nov 19, 2004 | 12:37 AM
agratise's Avatar
Default Re: IMPORTANT: Limiter at 6900 UPM but only in fifth gear! Whats wrong? (leed)
Yes i will post it in exactly 2 hours! I'm at work right now and i have to go home first to get the bin file, its on my laptop!
THANKS!!!!
Old Nov 19, 2004 | 12:38 AM
itsallmotor's Avatar
From: rigged and ready., WashingtonD.C./FlagstaffAZ/TempeAZ usa
I tried babelfish.altavista.com but i just can't translate that post into english.
edit: i just realized you're from germany i apologize for the joke, you may have better luck in the boost forum, this forum is non-boosted motors, no superchargers, no turbos, no nitrous, good luck
Old Nov 19, 2004 | 12:41 AM
agratise's Avatar
Default Re: IMPORTANT: Limiter at 6900 UPM but only in fifth gear! Whats wrong? (itsallmotor)
what is the part you do not understand? I'm from germany so sorry if the english is bad!
edit: sorry for wrong forum!
Old Nov 19, 2004 | 12:44 AM
yeah sorry i didnt realize you were from germany, check my old post again, again good luck, my guess would be pressure in the manifold, are you running an fmu, checkvalves, or standalone, are you throwing any codes?
Old Nov 19, 2004 | 12:58 AM
leed's Avatar
What ECU is this on? Is your ECT sensor plugged in and working?
Old Nov 19, 2004 | 01:11 AM
agratise's Avatar
its a P30-G00 ECU
this is the base ROM i used:
http://www.joergschaudig.de/up...0.bin
maybe i should try another P30 ROM File? Actually the ROM is working fine except the "mysterious" limiter
Old Nov 19, 2004 | 06:10 AM
Dan GSR's Avatar
u using a jdm ecu?
Old Nov 22, 2004 | 06:33 AM
agratise's Avatar
Default Re: IMPORTANT: Limiter at 6900 UPM but only in fifth gear! Whats wrong? (Dan GSR)
solved the problem, i used a EDM P30-G00 ECU with a USDM File. I deactivatet the Speed Limiter but it didn't change anything. 115miles maximum speed! I Set it to 190miles but still at 115miles the limiter!
I convertet all the Tables i made to a EDM File and everything was Fine!
Thank you guys & greetings from cold snowy germany !
Old Nov 22, 2004 | 09:14 AM
SkRiBLaH's Avatar
so using the value 115mph as the max. gives unlimited speed?
iseereduseered
Mar 23, 2012 11:49 AM
harrison381
Honda Civic (2001 - 2005)
Dec 10, 2009 02:36 PM
black arrow
Honda Civic (2006 - 2015)
Feb 10, 2007 01:36 PM
Funkin Flux
Dec 27, 2006 12:22 PM
DCnotTHEshoes
Oct 20, 2005 05:19 PM
