Crank questions when building a motor...
When balancing a crank for a fully built motor...does the crank have to be balanced on it's own. Some people say that the crank should be balanced with the flywheel and crank pulley that your going to use.
Whats the truth behind this???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 »</TD></TR><TR><TD CLASS="quote">yeah just balance the crank on its own
</TD></TR></TABLE>yep
Earl correct me if Im wrong but I dont think its possible to balance a crank shaft, well the entire rotational assembly together. I think many people are under the impression that you connect the pistons, rods, and flywheel to the crank then spin it around and balance accordingly. I was under this impression too until I saw how my crank was balanced. All the peices are balanced seperately.
I know my pistons and rods were weight corrected to a certain limit. I know my crank was balanced also. I guess I'll just have them check the crank pulley to make sure the damper is working and it isn't creating any vibrations, and maybe balance the flywheel too...if thats what they do.
Thanks for all the replies.
Which reminds me, I don't have a flywheel yet. What should I be thinking of going with??? Stock, lightened...or a CM flywheel or something. It's for a fully built....35PSI motor.
Thanks again guys.
Thanks again guys.
All aftermarket flywheels are balanced at the factory.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">Earl correct me if Im wrong but I dont think its possible to balance a crank shaft, well the entire rotational assembly together. All the peices are balanced seperately.</TD></TR></TABLE>correct
balancing all of the components together means those componets must be used together.
This leads me to believe any shop that tells you that the rotating assembly needs to be balanced together is trying to sell you on a half *** job.
I know I'd like to be able to swap a flywheel if needed.
Speaking of flywheels.... B16a1 ef9 what are you going to do with the car? A heavy flywheel can actually help acceleration. Remember it stores inertia while reving. A light one will give you more engine braking...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl »</TD></TR><TR><TD CLASS="quote">All aftermarket flywheels are balanced at the factory.correct</TD></TR></TABLE>
My Fidanza wasn't balanced...My Clutchmaster Twin and Tilton were, tho.
