87 Accord Ignition Switch or Trans Switch?
Old Nov 18, 2004 | 12:38 PM
Redicliff@honda-tech's Avatar
Default 87 Accord Ignition Switch or Trans Switch?
87 Accord LXi occasionally dead at key turn.
Jiggle transmission switch in and out of Park
Eventually ignition as expected.
Not 100 % sure it's the Transmission In gear cut off or not.
What is the name of that Transmission switch?
Does anyone know which might be expected to go first?
The key ignition switch or the Tranny cut off?
What sort of a job is it to change either or both?
All assistance is appreciated
Thank you CR
Old Nov 18, 2004 | 01:33 PM
Desslok's Avatar
Default Re: 87 Accord Ignition Switch or Trans Switch? (Redicliff@honda-tech)
Nuetral safety switch on the tranny. Hold the key to start and wiggle the shifter. If it starts every time like that it is most likely that. You can unplug it and jump the 2 wires to bypass it, drive it like that for a week and you will know. You have to put it in P to get the key out so odds are 99.9% you will start the car in P anyways.
Old Nov 20, 2004 | 11:28 AM
Default Re: 87 Accord Ignition Switch or Trans Switch? (Desslok)
Desslok,
Thank you. Super recommendation.
I just lubed the ignition switch perchance it was dirty.
Will try your recommendations next.
Thank you.
Old Nov 27, 2004 | 04:56 PM
The test indicates the neutral safety switch
Where can I unplug it?
Thank you.
redicliff
Old Nov 28, 2004 | 06:44 AM
86si's Avatar
the switch is not located on the trans. it is on the shifter assembly. just remove the cover around the shifter and it is on the left side of the assembly.Very common on older hondas
chaza
Jul 21, 2012 06:45 PM
JONESER
Aug 21, 2008 07:44 PM
Rushesright
May 20, 2008 07:31 PM
b00sted4dr
Jul 31, 2006 05:00 PM
