Ignition Switch??
Old Aug 18, 2008 | 01:01 PM
JONESER's Avatar
Default Ignition Switch??
1991 Accord auto
Car starts everytime with the remote start but when I put the key in to bypass the brake switch, the car dies. I took the ignition switch out and it'll start with a screwdriver. As soon as I let off with the scredriver, it dies again.
Why will it start everytime with a screwdriver & remote start but not with the key?
Is my ignition switch bad?
I the switch wasn't like $60 I'd replace it right away. I'm just trying to get some knowledge from the Honda experts so I don't blow a bunch of money that I don't need to be blowing.
THANKS!
Old Aug 18, 2008 | 04:45 PM
Mr Yamada's Avatar
Default Re: Ignition Switch?? (JONESER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JONESER &raquo;</TD></TR><TR><TD CLASS="quote">1991 Accord auto
As soon as I let off with the scredriver, it dies again.</TD></TR></TABLE>
This statement points to the ignition switch;
Contacts on the back of the switch melted or dull looking solder joint?
Many times you can release very slowly and the engine will continue to run, as the contacts change position
Old Aug 18, 2008 | 09:05 PM
JONESER's Avatar
Default Re: Ignition Switch?? (Mr Yamada)
Yeah, two of the soldering points looks like the solder has gotten hot enough to melt. None of the contacts are touching though.
Old Aug 21, 2008 | 03:24 AM
lowtegsr's Avatar
i just changed my ignition switch because of that, but my new one didn't have the little black plug that screwed into the key cylinder, and for some reason my headlights won't come on now. does urs have the little black plug?
Old Aug 21, 2008 | 08:39 AM
gqstatus05's Avatar
Have you tried to resolder those joints? Maybe that'll work.
Old Aug 21, 2008 | 04:41 PM
lowtegsr's Avatar
Default Re: (gqstatus05)
ok i figured it out, on the top of my steering column there's a red and white plug, i didn't remember pulling it but it was kinda hidden, it controls the headlights, tail lights, and dimmer switch.
Old Aug 21, 2008 | 07:44 PM
JONESER's Avatar
Default Re: (lowtegsr)
It was deff. the ignition switch. I went ahead & got one and solved the problem...so far.
h2oiamwater
Nov 26, 2016 12:48 AM
chaza
Jul 21, 2012 06:45 PM
InvaderTrax
Mar 1, 2007 09:39 AM
b00sted4dr
Jul 31, 2006 05:00 PM
Redicliff@honda-tech
Nov 28, 2004 06:44 AM
