Gear slips out of fifth when throttle is not pressed
Old Nov 18, 2004 | 11:24 AM
knalige's Avatar
Default Gear slips out of fifth when throttle is not pressed
When my throttle is not pushed down when crusing in 5th it just slips out....any suggestions?
Old Nov 18, 2004 | 11:29 AM
nightrider's Avatar
Default Re: Gear slips out of fifth when throttle is not pressed (knalige)
i may be wrong, but i'm guessing syncro?
Old Nov 18, 2004 | 11:56 AM
FerioVtec94's Avatar
thats good ole honda sychros for you
Old Nov 18, 2004 | 12:01 PM
Slow_Em1's Avatar
Default Re: (FerioVtec94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FerioVtec94 &raquo;</TD></TR><TR><TD CLASS="quote">thats good ole honda sychros for you</TD></TR></TABLE>
Old Nov 18, 2004 | 01:39 PM
B2FiNiTY's Avatar
Check your tranny fluid, it could be low.
Old Nov 18, 2004 | 03:51 PM
nightrider's Avatar
Default Re: Gear slips out of fifth when throttle is not pressed (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Check your tranny fluid, it could be low. </TD></TR></TABLE>
would low tranny fluid really cause this type of problem?
Old Nov 18, 2004 | 05:33 PM
knalige's Avatar
Default Re: Gear slips out of fifth when throttle is not pressed (nightrider)
ok how much do syncros run?? do you get separate ones for each gear or a set of gears at a time?
Old Nov 18, 2004 | 05:34 PM
Spoon Spec EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nightrider &raquo;</TD></TR><TR><TD CLASS="quote">
would low tranny fluid really cause this type of problem? </TD></TR></TABLE>
Low tranny fluid can cause all sorts of problems.
Old Nov 18, 2004 | 05:35 PM
http://www.acuraparts247.com for prices and pics.
Old Nov 18, 2004 | 11:15 PM
Boges's Avatar
would low tranny fluid really cause this type of problem? </TD></TR></TABLE>Absolutely. This exact problem happened to me, and it turned out to be an incorrectly seated axle, leaking tranny fluid all over.
Definitely check the fluid level before you go replacing synchros.
Old Nov 19, 2004 | 05:27 AM
Dr Pooface's Avatar
Default Re: Gear slips out of fifth when throttle is not pressed (Boges)
How do syncros help the car stay in gear?
Old Nov 19, 2004 | 05:33 AM
hype r 555's Avatar
Default Re: Gear slips out of fifth when throttle is not pressed (Dr Pooface)
I had the same exact problem but it did it in 3rd gear and when I brought the car in they replaced the syncros so........more than likely that's what it is...If your not doing it yourself be prepared for some serious $$$$$$$$ to have those installed by Honda/Acura...
StOnErTuNinG
Apr 1, 2007 06:10 AM
Flux
Dec 4, 2006 07:25 PM
superhatchbackbros
10
May 30, 2006 10:19 PM
thugfolife2
19
May 17, 2004 10:45 AM
WONG FRIED RICE
Nov 20, 2003 07:41 PM
