$H!TTY Day to the DYNO, HELP!!!!!!
Old Dec 27, 2001 | 04:51 PM
dot's Avatar
dot
New User
Default $H!TTY Day to the DYNO, HELP!!!!!!
I have a 1996 Civic HB w/ B16a, Skunk2 Cams, AEM Cam Gears, Thermal Catback 2.5in exhaust w/ staight pipe (no cat), Skunk2 intake manifold, DC 4-1 Header, AEM Fuel Rail, AEM Fuel Pressure regulator, and VAFC. HERES THE PROBLEM!!!!!!!!!!!!!!!!!
With all that I only Dynoed at :
126.5 HP, 97.6 Torque!!!!
After tuning I got:
146.2 HP, 105.4 Torque!!!!!!!
Thats seems REALLY low for the stuff I have, What is the deal here?????
Help me out with any Replies
Oh Yeah JOTECH even tuned it!!!! Kenny Tran himself actually!
Thanks Alot guys!!!!
Old Dec 27, 2001 | 06:42 PM
VTEC4GS's Avatar
Default Re: $H!TTY Day to the DYNO, HELP!!!!!! (dot)
need more details like which ecu, any check engine codes, fuel pressure, stock compression, cam gear settings can give ideas also ...
sometimes the best turbo tuners can't do as good on the all motor front, they are so used to boost that they forget the fundamentals.
Greg
Old Dec 27, 2001 | 07:02 PM
non-VTEC's Avatar
wow...........those are pretty low numbers........is the engine rinning ok?
maybe the dyno is out of calabration?
Old Dec 27, 2001 | 07:10 PM
ForcedAccord's Avatar
Texas B*tch!
Default Re: $H!TTY Day to the DYNO, HELP!!!!!! (non-VTEC)
Just b/c Jotech tuned it doesn't mean ****. I would check to see the a/f and see how that is doing, after that is checked, I really don't know.
Those numbers are REALLY weak.
Old Dec 27, 2001 | 08:27 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: $H!TTY Day to the DYNO, HELP!!!!!! (ForcedAccord)
Do a compression check and a leakdown too.
You may have other problems that you didn't know about.
Old Dec 27, 2001 | 10:17 PM
SiREF8's Avatar
Default Re: $H!TTY Day to the DYNO, HELP!!!!!! (B18C-EJ1)
Damn that sucks I have a friend w/a 98 hatch w/a B16 in it and dynoed only 140@the wheels w/only a tuned VAFC. Where did you get the work on the motor done at?
Old Dec 27, 2001 | 10:56 PM
prsaumur-91ef-sihatch's Avatar
Default Re: $H!TTY Day to the DYNO, HELP!!!!!! (SiREF8)
I would DEFINATELY do a leakdoen test too. Sounds like one of the cylinders have lower compression. The compression should be pretty even across all 4 cylinders if you dont have blowby on them. Also do this: If you find one that is lower than the others take a tablespoon of oil and put it inside the cylinder (spark plug hole) and recheck your compression. Make sure you turn it a few times to get the oil in the rings. If your compression goes way up you have worn rings.
Try it man, i swear it works every time............
Old Dec 28, 2001 | 06:06 AM
J28S's Avatar
New User
Yeah, do a compression and leak down check first. Compression you're wanting about a 160ish on all 4 cylinders. Leakdown, you want anything below a 4% on all cylinders.
Don't feel bad, I have 98 ITR (road race only) w/ AEM CAI and DC Header (Open after the header) and I'm pushing 148HP at the wheels. Stock it was 160HP... And yes, my engine must be rebuilt (Compression is all over the place (approx.) 125, 90, 115, 100) (Leakdown (approx.) 13%, 26%, 15%, 22%).
Good luck!!!
Old Dec 28, 2001 | 08:26 AM
Mike K's Avatar
Default Re: $H!TTY Day to the DYNO, HELP!!!!!! (J28S)
Make sure the fuel pressure is right on. My friend lost 20hp because the FPR was set to 28psi on stock injectors w/ Skunk2 ECU.
Bumped it to 44psi and it made a world of difference.
The torque seems about right. HP is kinda low. Remember that Skunk manifold isn't doing you any good on that 1.6 because the plenum/runners are way to big IMO, for a 1.6 liter motor.
Old Dec 28, 2001 | 05:04 PM
dot's Avatar
dot
New User
Default Re: $H!TTY Day to the DYNO, HELP!!!!!! (Mike K)
Ok thanks for the help guys, here some info to help this problem.
Right now these are my settings:
Intake cam +4, Exhaust +\-0.
Fuel pressure is at 40PSI on stock injectors.
Compression is 180 all the way across!!!!
Leak down 3%.
ECU is stock P30
Hope this helps!!!!
Old Dec 30, 2001 | 12:24 AM
dot's Avatar
dot
New User
Also I had a 2 fouled out plugs!!!!!!!!!!!!!!! I replaced them on Friday and now the car is missing again!! WFT is the problem??? Help me out here!!!!
Thanks
Jonathan
Old Dec 30, 2001 | 08:48 AM
earl's Avatar
I'd look at the injectors in the two cylinders with plug problems. U might try swapping injectors between a good hole and a bad hole. If the spark plug goes away in the good cyl, then u will know it is an injector problem. If 2 injectors are running fat, this WILL cause your low whp prob on the dyno. If JoTech gave a s... about you, they could have figured out your problem while u were there. Find a shop more into customer service.
Old Dec 30, 2001 | 11:15 AM
dot's Avatar
dot
New User
Default Re: $H!TTY Day to the DYNO, HELP!!!!!! (earl)
Thanks Alot Earl!!!
Well I was driving today and the car started missing again!!!!!!!!!! I will look at the injectors tomorrow
Old Dec 30, 2001 | 10:08 PM
Vtec integra's Avatar
check your map sensor and o2 sensor
i changed my o 2 sensor and it made w world of a difference
Old Dec 31, 2001 | 02:23 PM
evo's Avatar
evo
New User
Default Re: $H!TTY Day to the DYNO, HELP!!!!!! (Vtec integra)
MAP sensor is it the one next to Tbody?
Have u check the fuel pressure?
Old Dec 31, 2001 | 02:58 PM
csufweed's Avatar
Thanks
Jonathan
I'd check the distributor. If that is bad, then the plugs would go fast. Could be just a simple problem like the distributor rotor is out. Cheap to fix, but its a bitch to diagnose. Took me a year to find cuz no one could figure it out.
Old Dec 31, 2001 | 04:29 PM
dot's Avatar
dot
New User
Default Re: $H!TTY Day to the DYNO, HELP!!!!!! (csufweed)
Well I looked at my old intake today and it had alot of carbon build up in it. SO I think I might run an injector cleaner throught it and see what happens. But also I am going to check the MAP sensor and distributor, cap, and rotor.
OH YEAH and JoTech is also consirnded about my car so they are going to take it on Thursday or Friday and redyno it. I also bought some Bosch Platinums today and ran the injector cleaner today. I left the car at the Dealership so when I get back on Wednesday I am going to check the Distributor and stuff!!!
Thanks For the feedback Guys!!!!!!!
HAVE A FUN AND SAFE NEW YEARS!!!!!!! (I KNOW I WILL!!!!!!!!!!!) + =
Old Jan 1, 2002 | 03:29 PM
neof69's Avatar
yeah that has to be low, my B16A3 put down 145hp and 106tq with just Tanabe exhaust and dc us spec 4-1.
Old Jan 4, 2002 | 04:34 PM
dot's Avatar
dot
New User
Default Re: $H!TTY Day to the DYNO, HELP!!!!!! (neof69)
Well now JoTech is backing out saying I must have a bad motor. They are also trying to say I dont have Skunk2 Cams. Even if I had Civic Type R cams they would make more than 146HP @ the wheel!!!!!!!!!!!!!! RIGHT????
THIS IS REALLY UPSETTING ME!!!!!
PDmatt2003
May 3, 2006 11:48 PM
Im-Gay
Aug 22, 2004 04:31 PM
nbintegracing00
Apr 17, 2004 11:39 AM
Senbonzakura
May 17, 2003 07:34 PM
shivers
Jul 12, 2002 07:32 AM
