Question regarding seat bolts
Old Nov 18, 2004 | 06:02 AM
vtec.dc2's Avatar
Default Question regarding seat bolts
I'm trying to remove slide rails, but i'm not sure on what type of bolt this is and how to remove it? Do i just pry it off?
Old Nov 18, 2004 | 07:07 AM
monicle's Avatar
Default Re: Question regarding seat bolts (vtec.dc2)
really hard to tell from that pic. Ive taken out the seats on my 96 civic and they were just standard bolts.
Old Nov 18, 2004 | 07:17 AM
fakemike's Avatar
Default Re: Question regarding seat bolts (monicle)
That might not be a bolt that you need to remove. Are you swapping the rails on to another seat?
It is kinda hard to tell with your crappy pic.
Old Nov 18, 2004 | 07:19 AM
vti444's Avatar
i noticed them all over my rails. they look like theyve been riveted on to me
Old Nov 18, 2004 | 07:23 AM
fakemike's Avatar
Default Re: (vti444)
Yeah, those rivets don't need to be removed to swap rails (if that is what your trying to do).
Old Nov 18, 2004 | 07:33 AM
vtec.dc2's Avatar
yep.. i'm trying to swap the rails onto another seat... passneger side got rivets.. i just need to remove 2 of them to get the swap going.. so far i've been trying to cut them down with circular saw.. its a slow progress.. i guess they won't separate if i try to pry it right?
Old Nov 18, 2004 | 08:00 AM
fakemike's Avatar
Stop cutting those! Those rivets don't need to be sawed off. Remove the pastic on the side of the seat and look for the correct bolts to remove the rails.
When swapping seat rails there is no cutting involved just bolts.
Old Nov 18, 2004 | 08:15 AM
99Sivic's Avatar
Default Re: Question regarding seat bolts (fakemike)
Yah there rivets that go all the way threw. I took apart an extra set of rails and made a custom seat bracket. There are kinda a pain to get out. But i took a dremel cutting disk and just wanked it off. LOL Seem to work ok for me.
Hope this will help yah out.
Old Nov 18, 2004 | 08:30 AM
fakemike's Avatar
Default Re: Question regarding seat bolts (99Sivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Sivic &raquo;</TD></TR><TR><TD CLASS="quote">Yah there rivets that go all the way threw. I took apart an extra set of rails and made a custom seat bracket. There are kinda a pain to get out. But i took a dremel cutting disk and just wanked it off. LOL Seem to work ok for me.
Hope this will help yah out. </TD></TR></TABLE>
This is true if you are making custom seat rails. But if you are just swapping the rails on to del sol or integra seats you don't need to cut the rivets(Idon't know which you are doing).
Old Nov 18, 2004 | 09:04 AM
jay.dee.em1's Avatar
you dont need to do any of that stuff..if you are swapping seats rails between any type of honda/acura seats what you have to do is go to the bottom of the seat and remove the entire metal plate which is on the underside of the seat..the rails are attached to this metal plate..all honda/acura plates should be identical this way you just swap out the underside of the seat and it makes it much easier.. i know someone who did this when he put s2000 seats in his EG .. also i think there was a similar write-up on this site itself on some1 who did the same thing with s2000 seats in his EJ
ill seach for u
Old Nov 18, 2004 | 09:07 AM
Default Re: Question regarding seat bolts (jay.dee.em1)
here i found that thread for you hope it helps
https://honda-tech.com/zerothread?id=347548
Old Nov 18, 2004 | 09:37 AM
rpr's Avatar
rpr
That's fine if the seats don't have the same mounts for the rails, but if they do (such as Del Sol, EG Civic, DC2 Integra) then it's WAY easier to just swap the rails. And you DON'T need to grind anything, just do what was mentioned above, remove the plastic side panels and unbolt them.
rwdsohcef
Nov 23, 2010 07:03 PM
airikkCRX
Aug 14, 2010 05:36 PM
SomeDude56
Nov 13, 2005 10:01 PM
gleinz
Sep 25, 2002 12:33 PM
