ITR LCA's and ITR shock/spring assembly in a DA, will it work?
Old Nov 17, 2004 | 09:58 PM
SwedBoy2999's Avatar
Default ITR LCA's and ITR shock/spring assembly in a DA, will it work?
JDM DC Integra Type-R front and rear shock/spring assembly and rear LCA's in my DB2, just for now and it should give me more options as far as future suspension systems.
Will this bolt up and work just fine?
Better yet has anyone done it, or a 5 lug on a DA?
If you have a pict that would be sweet too!
Thanx in advance
Old Nov 17, 2004 | 10:55 PM
g2homboi's Avatar
yeah it will work u will need the front forks from an itr and rear lca's from the itr. 5 lug conversion has been done on g2 integras, check g2ic.com for pictures.
Old Nov 18, 2004 | 10:10 AM
Default Re: (g2homboi)
Anyone know if you can put a ITR sway on a DA i heard someone did it on G2IC but they didn't post how they did it?
Anyone know for sure?
Old Nov 20, 2004 | 05:44 PM
ek9jdm's Avatar
Default Re: (SwedBoy2999)
with some work yes
Old Nov 21, 2004 | 05:28 PM
jdmkrazie's Avatar
Default Re: (ek9jdm)
you can't bolt up the front's just like that. your going to need to get your DA steering knuckles bored out a little and stick the 5 lug hub in it. the rear will bolt right up fine. the only reason why you your not suppose to bolt the fronts up is because it will throw off the geometry of your suspension... you'll have hella bad camber.. and if i remember correctly it was lots of positive camber.
btw.. here's a link for instructions for the swap
http://battlecat.8m.com/ITR%20...A.htm
Old Nov 21, 2004 | 05:56 PM
Armed Ferret's Avatar
Default Re: (jdmkrazie)
sorry the pictures don't work--i just saved the .html file and hosted it as a mirror and never fixed the pictures. at least it's something to go with in your quest for shock information.
clicky
and here's a little info on the 5-lug conversion:
clicky again
Cesar_CPR
Jan 23, 2007 05:45 AM
ka-nife_
May 3, 2006 06:16 PM
Lissav
29
Mar 17, 2006 11:07 AM
One Bad GeeSeeR
Jun 24, 2004 02:49 PM
Reza.dc
Jul 7, 2002 02:14 AM
