Alternator
Old Nov 17, 2004 | 09:39 PM
Zatzy's Avatar
Default Alternator
Can a d16a6 alternator work on a B18b1....i know the answer is most likely no cause that would make no sense if it did, but then again the world does not make sense. so if anyone knows.
Old Nov 17, 2004 | 10:50 PM
Zatzy's Avatar
Default Re: Alternator (Zatzy)
help!!!!
Old Nov 17, 2004 | 10:59 PM
CrazyKoreanCrx's Avatar
i have a b16a2 with a b18c head. I have a d-series alternator runnin. Just need to fix the timing and water pump and code 15 and i'm good to go. You might have a problem with the bottom bolt for the alternator and which the pulley on the alt..
Old Nov 17, 2004 | 11:09 PM
RCautoworks's Avatar
Search a little, Phil has some nice pics of the difference, and no it will not bolt up.
Old Nov 17, 2004 | 11:12 PM
ServiceAdvisor's Avatar
Damn! I just formated my comp and lost all my Favs pages. There was a guy on this forum about 3 months ago fab a flange and he even had a paint diagram on how he built it; which let him use a d-series alternator. Ill keep searching and pm u a link if I come across it. - Darrell
Old Nov 17, 2004 | 11:29 PM
Nerologic's Avatar
Default Re: (DOHCZCCRXSi)
it CAN BE DONE...
the top hole aligns, all u need is some washes for the bottem section (is a bit narrower then B's) and your good to go
Old Nov 18, 2004 | 10:11 AM
Zatzy's Avatar
Default Re: (Nerologic)
thanks you guys. yeah DOHCZCCRXSi if you find that link that would be more then helpful. i just dont wnat to lose my alternator. its a 150 amp alternator.
Old Nov 18, 2004 | 05:54 PM
Zatzy's Avatar
Default Re: (Zatzy)
anyone else have any thoughts to this process?
Old Nov 18, 2004 | 06:17 PM
Nerologic's Avatar
i guess u never saw my post., a few posts up..
Old Nov 18, 2004 | 06:55 PM
Zatzy's Avatar
sorry man. as long as you are right thats awsome.....cause i want to keep that alternator. ill look more into your answer...thanx
Old Dec 24, 2004 | 05:11 PM
Zatzy's Avatar
Default Re: (Zatzy)
ok what if the bottom part lines up perfectly and the top would line up great if i just banged the top flange like 1/4" up so that the bolt will go through and grab the alternator? if i can get it on there and it lines up really good with the crank pully there is no reason i could not do this right?
utn
Honda Civic (2001 - 2005)
May 24, 2016 01:20 PM
MechEng
May 7, 2006 01:29 PM
