injectors
Old Nov 17, 2004 | 09:11 PM
civichatch666's Avatar
Default injectors
wondering if any one could recommened what size injectors to use on a turbo b20 with stock internals running 10lbs of boost
Old Nov 17, 2004 | 10:36 PM
MR5sARECOOL's Avatar
Default Re: injectors (civichatch666)
ask in the forced induction forum or tech??? I think you mind find more info there.
Have you tried to search for it?
GOOD LUCK
Old Nov 17, 2004 | 10:57 PM
Skunk.Werks's Avatar
You're gonna snap those rods like toothpicks and/or blow a few holes in your cylinder walls, you don't need to worry about injectors.
Old Nov 18, 2004 | 12:41 AM
mrspeaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk.Werkz &raquo;</TD></TR><TR><TD CLASS="quote">You're gonna snap those rods like toothpicks and/or blow a few holes in your cylinder walls, you don't need to worry about injectors.</TD></TR></TABLE>
How could you say that when you dont even know what his entire set-up is..?
Old Nov 18, 2004 | 12:48 AM
yellowcrx1991's Avatar
I think 450cc or so will do you fine.
Old Nov 18, 2004 | 05:34 AM
DaX's Avatar
DaX
Loved
Community Favorite
Go ahead and get 550cc or even 750cc. Lower duty cycle and room for expansion.
Old Nov 18, 2004 | 10:19 AM
Default Re: injectors (Mrspeaker)
why you say im going to snap rods and stuff every where i read they say it can handle 10lbs on stock internals no problem but if not how much boost do you recommened
Old Nov 18, 2004 | 10:37 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civichatch666 &raquo;</TD></TR><TR><TD CLASS="quote">turbo b20 with stock internals running 10lbs of boost</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrspeaker &raquo;</TD></TR><TR><TD CLASS="quote">How could you say that when you dont even know what his entire set-up is..?</TD></TR></TABLE>
How about you look before you post. Oh and B20 blocks aren't the super best for boosting, sure they can handle it but I wouldn't recomend 10lbs with stock internals. B20 is known for thin cylinder walls.
Old Nov 18, 2004 | 06:17 PM
mrspeaker's Avatar
Default Re: injectors (Skunk.Werkz)
How about you look before you post. Oh and B20 blocks aren't the super best for boosting, sure they can handle it but I wouldn't recomend 10lbs with stock internals. B20 is known for thin cylinder walls.</TD></TR></TABLE>
All He said is a b20 with 10psi..He never said what turbo..
10psi isnt the same with every turbo..He might have a t25 at 10psi for all you know
Which woudlnt be as dangerous as a 60-1 at 10psi..Learn about turbos before you talk garbage and confuse people..
Old Nov 18, 2004 | 07:11 PM
boost'dsiR's Avatar
ur call is peak and hold so use dsm 450
B18 rider
Aug 8, 2008 10:51 AM
LILSOWEK
Oct 18, 2006 04:08 PM
bootlegtrader
10
Sep 19, 2005 05:40 AM
crdcz03
Aug 8, 2004 05:21 PM
fredtoast
May 30, 2003 05:14 PM
