timing belt cover
Old Nov 17, 2004 | 08:17 PM
lunchboxEF91's Avatar
Default timing belt cover
Im trying to replace the headgasket on my d15 and i need to loosen the timing belt. The lower timing belt cover is a BIG hassle. I can only see 2 10mm screws, one on each side and it still doesn't come off. Any suggestion/pics is greatly appreciated.
-ruben
Old Nov 17, 2004 | 08:27 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
the crank pulley must be removed for the lower cover to come all the way off. in the center there is a plug, remove it and loosen the 14mm sockethead bolt.. thats the timing belt tensioner.
Old Nov 17, 2004 | 08:34 PM
COO! thanks for your help!
Old Nov 17, 2004 | 08:44 PM
smitty82pu's Avatar
better break out the air tools too or a big *** breaker bar because that crank bolt usually has ~150 ft. lbs. of torque on it.. good luck! we've all been there a time or 20..
Old Nov 17, 2004 | 08:59 PM
yea i just made a breaker bar not even 20 mins ago. Time to get down and dirty!
Old Nov 17, 2004 | 09:00 PM
EL Vap133's Avatar
Default Re: (lunchboxEF91)
Good luck taking off the crank pulley.
pmgriphone
19
Sep 4, 2015 08:11 PM
PRELUDEGURL98
Jul 17, 2009 05:01 PM
LSEGHATCH
30
Aug 18, 2005 07:32 AM
NX_LS
Oct 14, 2003 02:49 PM
Lei Siew Long
Jun 27, 2003 03:23 AM
