help on 96 hatch
I'm trying to take the bolt off that attatches the camber to the thing that holds the wheel and caliper/brakes apart (control arm?). Anyways when i try and loosen it the whole thing turns and there is a rubber stopper on top which restricts me from gripping it! It is really frustrating!
is it the 17mm ( w/ cotter pin) bolt where the hub goes in the LCA??? Usually I used a small impact to take that off work like a charm.
[Modified by SpeedracerS4, 11:07 PM 12/29/2001]
yeah the upper ball joint..if its turning when you are trying to loosen it just put some pressure on the upper arm by pulling down and that should help you get started...then use the ball joint tool to seperate
oh yeah its called the knuckle (that holds the hub calip.ect..)
[Modified by SpoonDeg, 7:56 PM 12/29/2001]
oh yeah its called the knuckle (that holds the hub calip.ect..)[Modified by SpoonDeg, 7:56 PM 12/29/2001]
I know exactly what ur talking bout (sort of) I had to do this recently, all you have to do is put some pressure on it by this i mean get a jack and jack up the whole disc with susp. this will put pressure on it, and keep it from spinning allowing you to take the bolt off.
plaiskool
33
Aug 7, 2004 03:42 PM
speed_racer012
32
Mar 12, 2004 02:58 PM
