Cleaning up ENGINE BAY, any tips???
Old Nov 17, 2004 | 07:01 PM
Hatch It's Avatar
Default Cleaning up ENGINE BAY, any tips???
I am going to clean my engine bay this weekend, it will probably be the first time it has ever been touched sicne it was made in 92, I just got it BTW.
But how can i go about it? IT IS COMPLETELY STOCK under the hood, should i cover the intake and powerwash it? Spray it with some sort of chemicals? anybody have any ideas? Please let me know...
Thanks alot
Old Nov 17, 2004 | 07:02 PM
green-'s Avatar
Default Re: Cleaning up ENGINE BAY, any tips??? (R0bCee)
make sure you cover up your electrical, ie dizzy, distributor etc..
boostedcivicsir's Avatar
Mr. Badwrench
we use SLAM where i work, but gunk is good too. just dont saturate your dizzy. do it while it is running. and avoid saturating any electrical stuff. i SLAM my engine every time i change the oil.
Old Nov 17, 2004 | 07:04 PM
Hatch It's Avatar
Default Re: Cleaning up ENGINE BAY, any tips??? (boostedcivicsir)
Ok whats a dizzy? sort of new sorry....
But what about some green stuff or something like that? I heard it works real good...
Old Nov 17, 2004 | 07:12 PM
dohcdelsol's Avatar
dizzy = distributor gangsta style
Elbow grease is your friend
civictildeath's Avatar
dizzy is the distributor
Old Nov 17, 2004 | 07:16 PM
Cuong-nutz's Avatar
I've used the Foam GUNK and pressure washer. Just make sure you cover up the dizzy and intake. Avoid soaking any electrical units/plugs for a long time. Just spray on the GUNK. let it sit for a bit and blast away with the pressure washer.
Other method is a toothbrush and simple green
Old Nov 17, 2004 | 07:18 PM
Default Re: Cleaning up ENGINE BAY, any tips??? (Cuong-nutz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cuong-nutz &raquo;</TD></TR><TR><TD CLASS="quote">Other method is a toothbrush and simple green </TD></TR></TABLE>
ya go air force deck cleaning style
Old Nov 18, 2004 | 06:04 AM
New Image's Avatar
Default Re: Cleaning up ENGINE BAY, any tips??? (civictildeath)
Cover up distributor cap and alternator. Spray DEGREASER generously all over (except the areas noted above and don't soak the spark plugs!) basically rule of thumb is to not soak any part and keep the water spray moving). Let the degreaser sit for a few minutes and spray off with hot water. Some problem areas will require more attention. Just do this until it is clean then wipe dry and remove plastic (used to cover up those part). Clean your engine a little more regularly and make it easier on yourself. Good luck.
Old Nov 18, 2004 | 06:26 AM
EliteCivicX's Avatar
DO THE ABOVE.....+ use this degreaserr **** they sell at advanced.........makes the bay SHINE !
Old Nov 18, 2004 | 06:27 AM
steve00si's Avatar
Default Re: Cleaning up ENGINE BAY, any tips??? (94JDMEG)
go buy some castrol degresser and spray that **** on you motor while its running and then let it sit for like 10min and then turn your motor off and spray it off. this is what we used at work. i am a detailer at a car dealership. if that doesn't work just spend the time and scrub it.
Old Nov 18, 2004 | 06:33 AM
kr's Avatar
kr
Default Re: Cleaning up ENGINE BAY, any tips??? (steve00si)
i just use simple green then when im done, USE the tire foam. ie the tire foam that makes your tires all shiney, spray it all over your your engine,hoses,and the body but do it lightly.(lightly)
Old Nov 20, 2004 | 07:57 PM
Slow_Em1's Avatar
Default Re: Cleaning up ENGINE BAY, any tips??? (green00EX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green00EX &raquo;</TD></TR><TR><TD CLASS="quote">make sure you cover up your electrical, ie dizzy, distributor etc..</TD></TR></TABLE> battery as well.
Old Nov 20, 2004 | 08:05 PM
JDMlyfestyle's Avatar
here is one i did this past summer for a HT member
Decided to help a fellow H-T member with his new car. and his filthy engine bay. came out 100x better than what it started with. Hid alot of wiring and rerouted the wiring. cleaned it up alot. Enjoy
Here is what we had to start with.
Me workin on TJ's wiring
Almost Done
There now it looks 100x better
Old Nov 20, 2004 | 08:06 PM
gamby's Avatar
Roll of shop towels + Simple Green, Armor All and some time.
Old Nov 20, 2004 | 08:08 PM
gamby's Avatar
Default Re: (JDMlyfestyle)
JDMlyfestyle--
Wow, I'm jealous of that engine bay!!! Nice work, man. I've been meaning to do this to both of my cars for some time now. Something else always manages to get in the way
Old Nov 20, 2004 | 08:10 PM
unbelievableEG's Avatar
Default Re: (gamby)
try degreaseer
Old Nov 20, 2004 | 08:15 PM
94_HATCH's Avatar
simple green along with degreaser and a lot of shop towels.
Old Nov 20, 2004 | 08:20 PM
gamby's Avatar
Default Re: (94_HATCH)
Simple Green is a degreaser, FYI
Old Nov 20, 2004 | 08:29 PM
Simple green is a mild degreaser. Gunk is a heavy duty degreaser.
on the engine bay above i used
2 tooth brushes
1/2 gallon of simple green
2 cans of GUNK
garden hose
and alot of elbow grease
Old Nov 20, 2004 | 08:34 PM
f1z1c's Avatar
Wrap up the electrical stuff in plastic bags- alternator, distributor cap, harnesses, fusebox, battery. The gunk foaming cleaner works good, use the whole bottle. Let it soak and rinse with a light stream of water, then attack nasty spots with the castrol degreaser, rinse lightly, and dry it off with shop rags. Dont get crazy with running the engine because it could suck water. A little water is ok but if that goes up in there in a big way the engine might croak. Ive seen mechs ruin alternators cleaning the engine, so be sure and bag all that.
Old Nov 20, 2004 | 08:38 PM
aone's Avatar
all i used is simple green and high pressure washer and it worked well. jus make shure u wipe it after u wash it
Old Nov 20, 2004 | 08:40 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (aone)
some brake cleaner worked pretty good for me.
Old Nov 20, 2004 | 08:47 PM
Tad's Avatar
Tad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">here is one i did this past summer for a HT member
wow nice job!
any good wiring hiding tips?
Old Nov 20, 2004 | 08:58 PM
Hatch It's Avatar
Default Re: (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">
wow nice job!
I already PMed him lol, but yeah hes working on them, i say just cut wires, make them ultra long, hide them low, and put black ricer loom over them to hide em, works good for me so far, ill get pics later
