Gauge cluster problems
the RPM and Speedometer gauges go move up and down when i signal or use hazards. Also the Temp gauge goes straight to hot when the car is turned on. Any suggestions on how to fix it? it is not the original cluster
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilovemydc2 »</TD></TR><TR><TD CLASS="quote">the RPM and Speedometer gauges go move up and down when i signal or use hazards. Also the Temp gauge goes straight to hot when the car is turned on. Any suggestions on how to fix it? it is not the original cluster</TD></TR></TABLE>
Sounds a LOT like a grounding problem. Check the wires y0.
-Chris
Edit, it sounds like the ground for the dash isn't making a solid connection, because power from the hazard indicators, etc. are causing voltage spikes in the rest of the dash.
-Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilovemydc2 »</TD></TR><TR><TD CLASS="quote"> it is not the original cluster</TD></TR></TABLE>
did it work correctly at one time ? or is this a replacement install that hasn't worked properly. I tried to replace my 97 cluster with a 2001 cluster and it did something similar. I ended up changing all the gauges from the 2001 cluster to the 97 housing to make it work correctly.
If it worked correctly at one time then take it out and tighten all the philips heads on the rear of the cluster ..... that fixed mine another time.
dudes great topic and i also need help on it...
Heres the deal i have ah 97 Ls 5speed with ah 00 GSR cluster(and also tried ah 99 ls but same story). the only thing that werks on the cluster is the speedometer..The gas needle goes alllll the way ta full and the temp needle stay allll the way ta cold..the cruise control light stays on as well as the check engine light that just blinks and blinks..whats one ta do since i don't have the stock 97 Ls cluster due too it being stolen..
5thgenallmotor
Dec 7, 2004 07:48 AM
som3on3_10
Jun 10, 2004 05:36 PM
