could this be rod knock?
Old Nov 17, 2004 | 05:30 PM
dpine's Avatar
Default could this be rod knock?
hello all
I have a b18c1 in a crx. When ever I start the car up after its been sitting for a while (probibly every few weeks) I here a sound that kinda sounds like rod knock (a semi loud noise coming from the bottom end)when I start it up. The sound only last for about a minute at idle while its warming up and then it goes away. I am just wondering if I have a potential problem happening.
thanks
Old Nov 17, 2004 | 09:54 PM
Kataku2K3's Avatar
Default Re: could this be rod knock? (dpine)
By rod knock to mean rod bearings going out? If it goes away once the motor is warmed up that's most likely not the problem. You sure it isn't just valvetrain noise, if your rockers are a bit loose sometimes when they warm up the sounds will go away as everything expands a little. To be sure, while the motor is warming up simply pull off each plug wire one at a time. If the knock goes away when you pull out the spark plug wire for that particular cylinder and comes back when you plug the wire back in then you just may have a rod bearing problem. Hope this helps.
EDITED: My word order didn't sound correct...
Modified by Kataku2K3 at 1:29 AM 11/18/2004
Old Nov 17, 2004 | 11:39 PM
PrettyLude's Avatar
good explanation
Old Nov 18, 2004 | 06:40 AM
dpine's Avatar
Default Re: could this be rod knock? (Kataku2K3)
no the sound is definitly coming from the bottom end. could it be the oil pump? I will try what you said to do today.
RevrsOne
Other Make Vehicles
Aug 21, 2012 06:50 PM
Myztikal
Apr 28, 2007 07:45 AM
blackhatchb20
Feb 14, 2006 02:45 AM
mnskateboarder
Apr 18, 2005 04:55 PM
turboex
Aug 30, 2004 10:42 PM
