PCV issue
Old Nov 17, 2004 | 04:57 PM
Reelizmpro's Avatar
Default PCV issue
I broke the PCV valve installing my AEBS intake manifold. I realize the purpose of this valve but is it needed? Should I buy another one or just bypass it with a hose? I have heard that the stock PCV's are barely sufficient and can go bad without warning. If this is the case it seems bypassing it with a straight hose would be better. Thanks.
Old Dec 30, 2004 | 01:03 PM
tr3-2001SE's Avatar
Default Re: PCV issue (Reelizmpro)
Definitely replace the pcv valve. I found out through oil analysis the importance of this item to the health of your engine. Anyone who bypasses this item is abusing their engine to a greater or lesser degree. I learned this lesson the hard way.
Old Dec 30, 2004 | 02:19 PM
DOHCtorTHRUST's Avatar
Default Re: PCV issue (tr3-2001SE)
replace it! i had to rebuild two motors because i didnt hook it up and all of my motor oil came out without me noticing it(long story). my motor is well lubed now since its hooked up..
Old Dec 30, 2004 | 05:29 PM
sander's Avatar
2.7(p/t)
The pcv valve regulates the vacum placed on the crankcase, you dont want too much vacum or you will start pulling on the seals, and other things will start going down hill.
PCV valves are important. Replace it.
-s
mclasser
Mar 26, 2013 04:06 AM
vteg98
Oct 24, 2006 07:05 PM
dukwei
May 13, 2005 06:05 AM
Reelizmpro
Nov 17, 2004 05:16 PM
BpuTacoma
Mar 22, 2002 10:00 PM
