radiator leak....and what I did to fix it !
Old Nov 17, 2004 | 03:46 PM
MikeTV
Guest
Posts: n/a
Default radiator leak....and what I did to fix it !
Well I just wanted to add this to the archives so you guys have a cheap alternative to replacing your radiator.
6 days ago I smashed the right corner of my car; the ac condenser punched a small hole in my radiator. I tried to drive my car back home and the whole way my radiator's leaking like a chick in heat. Well i didnt feel like dishing out 300 for a new radiator, so I dragged my *** to pepboys and picked up some gas tank/radiator sealant. it's basically a little roll of black epoxy/glue thats costs 3 dollars. I got home, plugged the hole with the stuff, and no more leaks. for saving me 300 $, it is worth its weight in gold !
Old Nov 17, 2004 | 04:44 PM
yeeb18c1's Avatar
Default Re: radiator leak....and what I did to fix it ! (Eclipse spanker)
get a new performance radiator from Fluidyne would do good....fix = worthless
Old Nov 18, 2004 | 12:34 AM
korean_teg's Avatar
Thats a temp. fix. It will leave u stranded somewhere. Goto radiatorbarn.com and just shell out $123.00 shipped.
Old Nov 18, 2004 | 09:24 AM
PnX-R's Avatar
Wow, much of that stuff did you use??.. The whole bottle maybe??
High five dude, you've just screwed up your cooling system. By using those pelets to plug up your radiator from the inside out, you've clogged your radiator and worse yet, even your heater core..
You don't have to take my word for it, just ask a technician..
Old Nov 18, 2004 | 10:24 AM
sabotage7's Avatar
Default Re: radiator leak....and what I did to fix it ! (PnX-R)
it sounds like he actually used the putty stuff, not the pelets....the putty stuff isnt bad to use, ive used it before..... its just a temp fix though.....you should really get a new radiator as soon as you have the money so you wont get stranded somewhere!
Old Nov 21, 2004 | 08:42 AM
MikeTV
Guest
Posts: n/a
Default Re: radiator leak....and what I did to fix it ! (sabotage7)
how does epoxy/glue sound like pellets ? If I were a betting man I would say that was putty, sherlock.
Anyway about screwing up your cooling system, keep your urban legends to yourself. they stuff has been on for close to a week now, and not one single problem yet. If it ever does cause i problem, I'll be the first to let you know.
Old Nov 21, 2004 | 09:15 AM
sabotage7's Avatar
i hope you werent talking/responding to me, cuz thats what it looks like!
Old Nov 21, 2004 | 09:34 AM
Ti3d in's Avatar
That stuff does work. I used the BARS radiator leak stuff, and I've had no problems in months. Best 3 bucks spent
Old Nov 21, 2004 | 10:08 AM
no2unenolife's Avatar
Default Re: radiator leak....and what I did to fix it ! (Ti3d in)
i used that stuff. it lasted my about a good 6 months, but definately get a new radiator if you can.
Old Nov 21, 2004 | 10:57 AM
MR-MUGEN's Avatar
Default Re: radiator leak....and what I did to fix it ! (climaxpinoy)
hmmmm. i don't know
Old Nov 22, 2004 | 06:45 PM
posjr's Avatar
Default Re: radiator leak....and what I did to fix it ! (jdm92daintegra)
Use an egg!
Old Dec 1, 2004 | 05:44 AM
MikeTV
Guest
Posts: n/a
Default Re: radiator leak....and what I did to fix it ! (posjr)
ya I def. will get a radiator as soon as I can round up a few bucks !
Old Dec 1, 2004 | 06:47 AM
Rory Breaker's Avatar
Good temporary fix. When you do get a rad, I would just pick up a used OEM from the classifieds or a junkyard. They go from $50-$100. No sense in getting an aftermarket stock replacement. My OEM radiator lasted 120k before I blew a hole in it, cant ask for much more!
Old Dec 1, 2004 | 03:23 PM
MikeTV
Guest
Posts: n/a
Default Re: radiator leak....and what I did to fix it ! (newgsrdriver)
but dont the aftermarket rads cool the engine alot more ?
Old Dec 1, 2004 | 03:28 PM
The aftermarket $$$ radiators like koyo, fluidyne, etc, sure theyre more efficient. Its not so much that they cool the engine "more". I was referring to the radiators.com or radiatorbarn or pep boys replacement radiators though, not the "upgraded" aftermarket radiators.
For most applications, you don't really need that level of efficiency. There is a large price difference that doesnt justify the upgrade unless there are other factors involved (fitment, high temp conditions, etc) IMO.
Old Dec 3, 2004 | 07:45 PM
MikeTV
Guest
Posts: n/a
cool thanks
Old Dec 3, 2004 | 08:12 PM
Stripped Honda's Avatar
99-0104
i sell KOYO oem style radiators for 120 (not the complete aluminum aftermarket style one) ... so i see no use in fixing the old one .... also be carefull in the radiators from radiator barn ... so many people have complained about the quality from there it almost makes me think they are not top quality ...
Old Dec 4, 2004 | 01:31 PM
MikeTV
Guest
Posts: n/a
Default Re: radiator leak....and what I did to fix it ! (Stripped Honda)
are the rads that you sell genuine koyo ?
sdinteg
Jun 1, 2010 11:26 PM
oovvutt
25
Dec 25, 2007 02:56 PM
eastsideATX
Jul 6, 2005 02:56 PM
kingpen
Oct 31, 2002 12:19 PM
EGh22aEG
Jan 9, 2002 06:37 PM
