Which side of gasket to apply hondabond...
I've searched and can't find the answer I'm looking for. I'm going to install a new valve cover and gasket. I am wondering if I'm supposed to apply hondabond on the head side, the cover side, or both sides of the gasket.
Modified by 8point6 at 4:33 PM 11/17/2004
in my Helms for my B-series it shows as in between the gasket and valve cover. especially in the corners of the cams curves
Don't apply it all around, just in the corners where it goes over the cam caps. The rest will just squeeze out and make a mess.
I know that, my question is concerning which SIDE of the gasket to put it on.
Thanks though.
Thanks though.
1. Turn the valve cover upside down.
2. Install the valve cover gasket.
3. Apply a small dab of Hondabond to the corners of the valve cover gasket where the valve cover goes over the cam caps. You should have 4 spots on a single cam, 8 on a dual cam.
4. Install valve cover and tighten bolts.
5. Perform burnout.
5. Perform burnout.
i like that
